- Jul 14, 2020
- 125
- 6,164
- 7,039
- California
- Jeep Wrangler JKUR
- Wildtrak
This may come across rough, but I'm pretty pissed right now.
When I wired up my winch, I wanted to do it right. One of the features was I wanted a relay in between the winch and the battery so that the big thick power cable running through the engine compartment and out to the front wasn't energized unless I needed it to be.
To make it even cooler, I wired up the relay to an upfitter switch (10a).
Anyway, after doing some research I had stumbled across the Warn winch relay...
https://www.warn.com/warn-industries-72631-winch-solenoid
This sounded perfect and after reading some reviews on Amazon about people getting non-genuine Warn relays, I decided to order my directly from Warn and take no chances.
Yesterday, I decided to test the winch (You know, test it before you need it!) So I pulled the full lenght of my winch line out and started to pre tension....
Now I didn't just hold the "IN" button, but was off and on it. Within 5 minutes, my winch stopped working. Took me a bit with a test light but found out the relay wasn't getting the power signal from the Upfitter. Checked the fuse and it was blown.
I was kind of like WTF ford..this relay should not have blown that 10a fuse but at this point I just need to get my winch line back in so I can drive. I replaced the fuse and my winch still didn't work.
Then I tested across the primary post on the relay...dead as can be.
So apparently, my Warn Winch Relay, which they claim is for their 10,000 lb winch...is total ggarbage. Glad I don't own any other Warn products.
i was able to move one of the cables over to the other post to bypass the relay and finished the job.
off to buy something better on Amazon..found a 500amp battery isolator that more than one person said they are using it for their winch... here's to hoping for better reliability!
