My MIC 2.0 started the popping noise at 1,300 miles
BroncoBill6G
Circleville, Ohio
2008 F350, 2017 Lincoln MKZ, 2018 Escape, 2016 Fus
I love my bronco but was surprised when my hardtop started the popping. I will be notifying dealer.
Bronco21fan
Angelo
NewJersey
Sorry to hear about your issue I hope they get this hard top figured out for all our sanity
Theherofails
Thomas
Phoenix
Mine too. It's the alignment pin over the driver side for me. I notice the front pins have a rubber condom and that rear pin does not. I took the panel off, cleaned around the pin and secured it tightly. Problem solved.
If it comes back, I'm going to put a little graphite lube on the pin or try to find a rubber condom to throw on it like the front pins.
Mike E
Denver
Badlands SAS 2.7
How about return it to the dealer and get it fixed? MIC 3.0 in the works yet?
Fly by Nite
Walt
Pa
Would a piece of shrink wrap over the pins work?
Theherofails
Thomas
Phoenix
likely. I think I saw someone post something about a piece of high density foam but I didn't quite understand what he meant at the time I saw it. Now it makes total sense.
dcliffo
Canton, MI
Bronco OBX
I've got a squeak/creak wherever I am on anything other than a perfectly smooth road.
Unlike you guys mine seems to be coming from the passenger rear corner of the cab portion. If I pop the swing gate glass and then pull on that edge of the opening it recreates the noise.
It looks like its where two parts of the panel have been bonded together.
Any of you getting anything from that back corner/do anything to fix it?
Jabberwock
Craig
Georgia
2011 Toyota Tundra
Hereā€™s my post on the solution you mentioned. It has worked for two different MICs so give it a shot and report back. The second time I did this I used a much thinner piece about 1/8ā€ thick and it worked just as well.
https://www.bronco6g.com/forum/thre...-solution-for-popping-rattling-mic-top.24207/
Jr87mustang
Josh
Northern Cali
Your exactly right, same spot for me. I haven't done too much about it yet as it is raining and I just usually unlock and lock the keepers there and it will stop for a few days, lol.
Jr87mustang
Josh
Northern Cali
Theherofails
Thomas
Phoenix
Jabberwock
Craig
Georgia
2011 Toyota Tundra
Thanks man. I tried like hell to find your post again.
No problem- happy to help. I hope it works for you. Iā€™m surprised more people havenā€™t shown interest in my solution. I guess as more folks take delivery that might change.
Theherofails
Thomas
Phoenix
I came to the same conclusion you did after examining the pins and realized it was exactly what you were talking about. Some of the pins are missing that little rubber condom and sure enough, those are the pins squeaking. I have your post bookmarked now to spread the good word.
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
Where can you buy the little condoms? I only know where to buy extra extra extra large size. šŸ˜
Ford Bronco My MIC 2.0 started the popping noise at 1,300 miles 1636498638709
Techun
Pa
BD, 2.7, MIC, 4dr
Mine has started making a very subtle noise, but I'm not sure it's the top. It sounds like it's more like driver left foot...but I have no idea.
If I take the top off, no way will I be able to hear it either way.
