amccue90
Illinois
Chevy Colorado
Swaybar reconnects automatically above 20 mph. At highway speed it would be connected regardless of driving mode.
good point, I kinda read past the part about it being on road haha
Edit: but I also think it's supposed to automatically re-disconnnect when you get back below 20. So turning could've been affected. I hope we're not just rolling around going straight on the highway.
Advertisement
Rubisquatch
Pittsburgh, PA
13 10A Rubi, 14 HR Rubi, WRX, 19 Edge
Thanks for the write up. So, if you were only getting Lux for the B&O sounds system, would you recommend going Lux or staying with high and therefore the base sound system?
Marauder
Josh
St Louis
Awesome stuff
having been a car guy predominantly and owning an SUV (Sorrento) for 5 years, I was curious what the following meant.
The body roll on the road was severe.
Is this similar to “Death Wobble?”
Thanks in advance!
Marauder
Josh
St Louis
No. Completely different. Body roll is just... body roll. It's not really an issue.
Ok. I want to say that’s good, but I’m still uncertain what body roll defines. Do I just feel “less” of the road?
Like, it’s softer but not meant for hugging a turn?
BroncoKong Jr.
2021 Bronco (ordered)
https://en.wikipedia.org/wiki/Body_roll
Every vehicle has it to an extent. It's more apparent on off-road vehicles due to the suspension.
Daktari
Oliver
at the base of Mount Diablo, CA
Tacoma TRD Off Road, Jetta
I understand body roll as the vehicle leaning outwards in tight or fast turns, which can give you the feeling of flipping over any moment (well, eventually if too tight and fast you actually will flip), and general side to side bounciness. I'm mostly used to it on my Tacoma TRD Off Road though at times coming down the mountain highways with 4 people and a full load of gear it can still be a bit puckery.
Compare to a sport car that will be pretty much glued flat to the road.
At least that's my understanding of body roll, even if the name is a bit odd.
ChrisD
2019 Ram 1500 Rebel, 2014 Cherokee Trailhawk
Thanks for the write up! That was the one I wanted to ride in when I was there since it is the same as my build, but it was taken, so I rode in the 2 door - I figure down the road, I'll do some after market lift and bigger tires, but for a while, I plan on running the 33s to get used to it.
I've had about 5 different Jeeps and a 5th gen Bronco, but am super excited about these.
BTW, that's the same Bronco as my avatar. :cool:
ZackDanger
Zack
Massachusetts
2014 Wrangler JKU
Awesome stuff
Thanks in advance!
Body Roll =/= Death Wobble.
Body Roll:
Death Wobble:
Gamecock
2011 FJ Cruiser
I generally like a stiffer spring than factory up front anyway and that significantly helps reduce body roll (at least in Taco, Ranger, 4Runner and FJ) and levels the front. I’ll likely do that in Bronco.
Raptor911
Raptor911
Ashburn, VA
2019 Raptor, 2018 BMW M2
Agreed!
SAS wheels are 30 offset. just going to a zero offset will make the Bronco more stable.
Regardless .. simple physics. The taller the vehicle the higher the center of gravity so you have to adjust accordingly. You just can't take corners like you would in a car.
Pressure makes sense, width does not. Putting the surfaces of the tires farther apart is literally one of the techniques for making fast vehicles more stable.
Southern Girl
1974 Bronco/2013 F-150 4x4
Vehicle Showcase
This is where many will have issues with the Bronco when they expect it to ride and drive like a Range Rover. It seems like the advent of its return has drawn people who wouldn't dare be caught in a Jeep, but will also have no frame of reference for these types of vehicles.
Thanks for the report @broncosor !
Denny Swift
Earth
718 Spyder, Clubman SAll4, 435XI, Husky FE250
Thanks for the write up! I just can’t comprehend how a vehicle like this would not offer magnetorheological shocks. Especially with all the goat modes. That makes zero sense to me. If the goat modes only adjust throttle response and automatic transmission shift points, they are pretty much worthless especially on a Bronco with a manual transmission. Cockpit adjustable shocks have been around for decades, and are standard on most vehicles in this price range. Boasting about all those goat modes when the suspension isn’t affected, just makes no sense.
Edit: Ok, maybe I’m wrong:
https://carbuzz.com/news/2021-ford-bronco-suspension-system-can-dance-to-music
https://www.motortrend.com/news/2021-ford-bronco-active-suspension-modes-patent/
According to this, the suspension is adjustable (hard to believe it isn’t), but everything I’ve read prior to this said the goat modes did not affect suspension. And if it is adjustable, I don’t understand why body roll would be excessive on the road.
Advertisement
Wide Open Roads
Advertisement
