My OCD modification of Central Console Lid
drvahe
Vahe
2022 Ford Bronco
Hey folks posting some photos from a minor modification of central console lid. , I didn't like that on my LUX package every time I was opening the central console lid it was just falling back like so cheap. So by cutting and foreshortening the springs the lid is more stable
Ford Bronco My OCD modification of Central Console Lid tempImagecgA1nV
Ford Bronco My OCD modification of Central Console Lid tempImageFuvFDz
DBC Offroad
Sean
Reno, NV
www.youtube.com
'23 Raptor & '21 4Runner TRD OR
I can't believe no one else responded to this.
Thank you for posting! This fixes exactly what I wanted!
spiG
23 BD/20 Ram 1500
Will definitely have to complete this! Thanks for the photos
Mad Martigan
Matt
Oklahoma
Fords and 1 Wrangler
Ok I need to do this. It seems like it’s always falling down on me even when I’m on an incline. I don’t think mine has a spring in it?
Ducati1098
It should have 2 according to the parts diagram. But mine is the same way, doesn't feel like one is even there and just easily falls down.
drvahe
drvahe
Vahe
2022 Ford Bronco
So cutting the spring made it pop up by itself? I’m not sure what that 2nd picture is that you posted. Can you elaborate some more? Thanks!!
you need to cut springs from both sides, by cutting springs as I did on the picture you making it shorter which creates more tension, but beside cutting you need to bend it in the same factory way which will require a lot of strength of your hands :). It will be more understandable if take out the back cover of central console you visualize the springs.
drvahe
drvahe
Vahe
2022 Ford Bronco
You have them but they are loose , doing nothing , I am not sure why ford did that to us :LOL:, but making those springs a little shorter will help
Stromad
Matthew
Northern NJ
2023 Bronco Badlands 4dr 2.7L
Awesome mod @drvahe 🙌
This bothers me to no end 🤬! What an egregious oversight!? The center console lid is always falling down when trying to access it, save for if the front of the vehicle is uphill, then you get stabbed by the latch beam.
Hoping one of us can spec a direct OEM swap replacement for the torsion spring but with a stronger force/resistance spec, different angle between legs, wire diameter, etc. Anyone look into this already? It has been some years since I've spec'd springs and am forgetting my go-to sources. Century Spring was one of them I believe...
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
I was thinking of adding a soft closing hinge some day like the one in F150
Ford Bronco My OCD modification of Central Console Lid 9b27e8446cd77abe7bab34f72ab99e7b
drvahe
drvahe
Vahe
2022 Ford Bronco
I am not sure how it will fit , but it will be nice. Great idea
Preheateddinner
S.
22 Ford Bronco BB 2D
I wish there was a shorter one to purchase also- I tried to do @drvahe 's modification, but I wasn't able to bend the spring hooks. He even says "it will require a lot of strength" and I simply don't have enough. I put the cut off spring in a vise grip and used channel locks on the hook end and gave it everything I had to no avail!
Can parts master @flip help us out?
