Callelk
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Dugout
Joel
ETX
24 Bronco
did add a 6 position terminal strip for the factory auxiliary switches.
Any special adhesive for the terminal? Also just a basic one off Amazon or Home Depot?
Thanks and sorry if you already mentioned. I’ve been plowing through your journey. Super helpful.
Callelk
Callelk
Larry
Idaho
Thanks. I just used a basic 35Amp one from Amazon. It has a snap on cover to protect the terminals incase I do something stupid while under the hood. https://www.amazon.com/gp/product/B0B24FZWPH/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I use 3M double sided tape. Typically, I clean the part with alcohol and apply the tape. I then remove the protective plastic and use a heat gun to activate the adhesive. I've not had an adhesion issue when I use heat to secure any type of tape.
HopBronco
Sean White
Ford Bronco
Hi - love your build. I just got a obx sas/lux and ordered 4x4truckled dynamo diode fog lights. Did you install all three lights into three aux switches, or did you pigtail one into the existing fog wiring, get a new interior light switch with fog, and update via forscan. I am trying to decide if it is worth it to do the latter for one of the fogs, so just asking to see what other folks with the same kit did.
Callelk
Callelk
Larry
Idaho
Thanks. I wiled the fogs to the factory fog switch. The combos are to switch #2. I used Forscan to have the fogs come on with the turn signal or when turning the steering wheel. The DD Fogs are much brighter than the factory but then I ordered the MAX so one would expect that.
Callelk
Callelk
Larry
Idaho
Final pieces to the puzzle.
Ford Performance Front Tow Hooks:
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8185.JPG
Ford wheel locks:
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8189.JPG
Had to use up my points.
Callelk
Callelk
Larry
Idaho
Desert Does It mount for my holsters and mag pouches. The mag pouches can hold my 1911 through my 30 round stick SMG mag's.
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8190.JPG
Callelk
Callelk
Larry
Idaho
Final interior pieces. Husky floor liners (saving the Bronco script ones):
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8186.JPG
MegaTek HD3 Seat covers and cheap pad from Amazon.
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8187.JPG
Patches..........
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8162.JPG
Callelk
Callelk
Larry
Idaho
Installed the ARB Twin Compressor. Since I have 2 handheld radios I decided that as I will be on trails 3 days a week starting in September, this took precedence over the Wouxun mobile.
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8202.JPG
endovein
jeff
delaware
bronco wildtrak
Can I ask what mount you used for the compressor?
Callelk
Callelk
Larry
Idaho
The KR Offroad mount, easy install and it actually took me longer to wire than install the compressor/mount.
Callelk
Callelk
Larry
Idaho
I finally got around to installing my GMRS Radio. I went with the MTX575, mounted under the console. Many thanks to shansen for the thread and help.
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8238.JPG
Ford Bronco My Race Red Heritage Edition 2024 Bronco Build & Story IMG_8241.JPG
I have checked everything off my-to-do list and finished my build-up. I know I added a couple of items to my original list and wish to thank all those that have given me too many ideas to list....
Callelk
Callelk
Larry
Idaho
As I mentioned, now that I have finished my build-up and going over my initial list, I’m looking back at the items I added and the reason for the additions.
  • Floor Mats – I like the OEM mats that came with my HE but they really did not provide the protection I needed when hunting. The Husky mats fill the bill here.
  • Aux Switch Block -Made it so much easier to wire and in a couple of instances I changed my mind on what was wired to what switch. Just moved them around as needed on the block, no wire cutting was involved.
  • ARB Under Hood Twin Air Compressor – Didn’t think I would go this route since I have a good 12V portable. The ARB cut my air-up time in half (or less) and freed up space in the cab.
  • M2M Box – Mounted it to the rear Molle and used it for dog training dummies in the summer and additional shotgun shell storage during the season. Great addition.
  • M2M Attic Shelf – One of my better decisions IMO. What was wasted space stores my 2 handheld GMRS radios, hoses for airing back up when I leave the trail, dog first aid kit, extra leashes and light rain jacket.
  • Magnetic Mic – Decided to change out my Garmin 200i mount to the Magnetic Mic mount as I already have the Garmin Tread GPS mounted and didn’t really need another GPS mounted on the dash but I did need to mount the mic.
jclark
Jeanette
Mid-Michigan
can you share the link to the aux switch block you used?
Callelk
Callelk
Larry
Idaho
