LOL!!!!!I had originally ordered the MIC, but changed my order back in April when I saw the Webasto iceberg on the horizon.
it looks like it might be possible to roll it from side to side, but not sure I'd want to do that for longer storage. There's a rubber seal along the top (and maybe bottom? hard to see in the videos) that most likely won't be happy. I sure won't be the first one to try...Can you roll up the big back panel?
I doubt it. Can't even do that on Wranglers anymore.Can you roll up the big back panel?
Ah ok, thanks and sorry for my confusionI was referencing the request for Ford to give a storage option. Say grooves along the cargo area to hang the windows up in the cargo area and get them off the floor (and out of seats). Of course that idea doesn't work because the rear window is so long.
Agreed. I'm close to 900 miles, and I like it. Took some practice to speed up on reassembly of the window panels, but it's clever. Wear and tear will be an issue, but we'll see what happens.I've had my badlands for about 2 weeks (950 miles) now. I had originally ordered the MIC, but changed my order back in April when I saw the Webasto iceberg on the horizon. I just thought I'd offer my opinions on the soft top.
It's nice only having to undo the 2 latches to flip it back. I love the ease of operation. The passenger side of my fabric wants to curl under whenever I flip it back to the sunrider position and I have to pull it out and make sure it folds correctly. I don't mind this too much as I always do a walk around to make sure it's good to go anyhow (thus, the purpose of the walk around).
Folding it fully back is pretty easy as well. I learned from a buddy who has already scratched his safety cage up, how to do it properly and not scratch mine up.as long as you're not in a hurry, and do it carefully you're good to go. I haven't tried it in windy conditions yet. To note, at delivery, mine already had felt pads to reduce rubbing on the inboard side of the hinges that cause the known issue.
I've seen where a few folks don't care for how the 3 rear windows come off, but I don't mind it too much. Getting the upper 3 buckles on each side put back in when reinstalling is kind of a pain with big hands. That's the one of only 2 things I find bothersome. The other is trying to install the rear window around that 33" tire, it's just in the way whether you leave the back door open or closed. But neither of those are a big enough deal to stop me from taking them out and putting them back in. I do wish there was a storage solution for the 3 windows when they are not installed @Ford Motor Company .
Road noise isn't too bad as far as I'm concerned. Without the lux, I find myself turning up the radio to less than half to hear the programming I listen to.
The only major complaint I'd have is the seam along the edge of the fabric is sewn in a way that it has a lip for water to run along. Unfortunately, this lip ends directly above the door lock switch, so that when you roll your window down at Chik-fil-A in the rain, a steady stream of water pours into the truck and all down the inside of the door. Loving the drain plugs!
All in all, I'm happy with my choice of going with the rag top. I've had 2 other convertibles, and this one met my expectations.
Edited to add pictures of the passenger side where I spoke about the fabric folding under, and after I straighten it out
This reads like a confusing description, but hopefully you get it: I am having less trouble with this since I realized that I need to press the top of the rear corner piece forward toward the front of the vehicle when it's time to get the bottom of the corresponding side panel started in hooking into the bottom of the rear corner piece.Getting the two side windows to snap into the groove by the rear passenger seat is a PIA. Not a fan - I hope that the fabric loosens up more with usage.
I would not roll that back panel, or any other panel.it looks like it might be possible to roll it from side to side, but not sure I'd want to do that for longer storage. There's a rubber seal along the top (and maybe bottom? hard to see in the videos) that most likely won't be happy. I sure won't be the first one to try...
I always have old towels with me, and have one in hand when fooling with door or window in rain. It is a good way to keep interior dust free, and you can drape them over seats in sun when ducking in a building. Towels also come in handy in my Corvette when using windshield washer with top down.Good review! Same issue with my '05 Mustang GT Convertible. I'm always prepared for a dribble when I roll down the window on a rainy day.
I'm also in Ohio (Central) and am making the choice to switch to soft top. I don't have long term faith in the Webasto top even corrected so I don't want to have to store or dispose of the hardtop. Just going soft top. It will be garage kept and also has a garage at work if I take it out in the salt.Thanks for the review. I'm a little torn after reading it, but still I'm in Ohio and I don't think I want a soft top in the winter. I'm glad you like yours though, congrats on winning the Bronco lottery!
Soft top will work fine here. You will want it more than the hard top as it rains every day, somewhere at sometime even with the sun out. So you must always be prepared and it's much easier to flip the top back than spend the 5 minutes putting the panels back in during a torrential downpour that ends before you finish. Of course there is always the besttop for hard top instead!I may have to move from the PNW to Orlando due to work. Any thought on folks in Florida if the Soft top works there with the heat? It was a no-go in Seattle with the Rain and the crime downtown.
Good morning! Can you please send us a private message with your VIN and some more details on your experience with the Bronco's soft top? I would like to see what I can do to assist with keeping the inside of your Bronco dry!I totally agree with your assessment. I've only had mine since Friday.
The water running into the door when you open it in the rain is a very annoying feature. I think their rain channel isn't thick enough.
Where is the scratching supposed to happen? I saw a little felt section on the arms. Does it scratch on the top rail? I want to make sure I don't have an issue there.
I was just tossing them in the cargo area, until I went to store the doors back there. With the doors, there's no room for anything else, so I used the seat belts in the back seat to strap them in.As far as storing the windows with the top down, where would you put them? This is something I wanted to tackle but couldn't think of a logical place to put that large back window.
