You’re not wrong.it looked so small next to the SAS that i thought it was a 2-door.
And you’re still married?My wife wants a Wrangler and I said NO. No way in hell Woman. I make the $$ in this family so either you get a Bronco or you keep your 2018 Lariat! GRRRR!
I’m sure his second wife will enjoy the Bronco.I am glad that your wife won the argument! ;-) You are just going to have to get used to the bronco...wait, what? Well done sir!
One Pedal seems to be tied to the 2.7. I'm not clear why. So, yes? Technically available on every trim but not on 2.3 whether manual or auto. I could be wrong, but that's what the order guide indicates to me.Here's a question to everyone. Is the 1 pedal option on every bronco trim?
Sheehy in Gaithersburgwhere are you seeing them tomorrow?
Thanks for the review. On 2.3 Mustangs it's already been discovered that Ford badly undersized the IC and replacing it is the most important mod you can do. I wonder if the Bronco 2.3 and 2.7 share the same IC, and if it's undersized.3 - The inter-cooler. Is there room to run a bigger one? BTW, upgrading the stock IC is a common mod in the Raptor world. It appears that there is little room for a bigger IC in the Bronco. In order to get a bigger IC, you will have to remove the IC louvers and if you did this how would you mount the ACC sensor?
Maybe this will help a little for the 2Dr crowd, from Moab.
