- Josh
- Apr 25, 2022
- 127
- 184
- 95
- Salem Ohio
- 2022 Bronco 4-door
- Bronco
- Badlands
N-Fab HPF2172B-TX Fits 2021-2022 Ford Bronco Podium Step Nerf Bars- Textured Black
N-Fab HPF2172B-TX fits the following vehicle: 2021-2022 Ford Bronco Step up the fashion and function of your pickup truck or Jeep with N-Fab Podium Step Nerf Bars Crafted from rigid stainless steel 3-inch tube construction features drop step Welded engineering minimizes weak points Specific to vehicle make and model Comes in pairs Bolt-on installation is simple and quick A Lifetime Craftsmanship Warranty is included Climbing into a truck with a lift kit or even a stock truck can be challenging for your passengers and exhausting for your knees. Adding nerf bars is a perfect option to address the problem and improve the overall look of your vehicle at the same time.
With N-Fab Podium Step Nerf Bars, you can climb into and exit your rig safely, stylishly, and with confidence. Your N-Fab Podium Step Nerf Bars are constructed using rigid Stainless Steel tubing that's been forged into 3-inch tubes. The well-spaced hoop steps and sure-grip traction plates are broad enough to accommodate massive boots and prevent slipping even in the wettest or muddiest of weather conditions.
These bars are welded into a single piece and designed to eliminate stress spots that might eventually lead to buckling or shearing. These cab length bars are sold in pairs and custom-measured to match your specific make and model. The bolt-on installation takes only a few minutes and relies on existing holes in your vehicle's frame, so you won't need to charge your drill or compromise your bodywork. A 5-Year Warranty is included with the durable Black Powder Coat finish, and a Lifetime Warranty is included with the bright and brilliant Polished Stainless Steel finish. N-Fab offers a Lifetime Craftsmanship Warranty on the workmanship.
Advertisement
