Builtright industries has a plate that is a good size for the tailgate.Same, dude. Just a small panel I could hang a few things from, and would keep the tailgate clean.
Is that panel bronco specific? I couldnt find it
Thats it. I also got the mounting hardware kit along with a few other things to mount. The only holes drilled are covered by the plastic trim piece.Whoops i found it right here.. thanks
https://builtrightind.com/products/tech-plate-25-0-x-15-5-universal-molle-mounting-panel
Great idea - just ordered one. I wonder if butterfly anchor bolts would work to attach to the swing gate? Probably depends on whether the molle panel holes align to the swing gate holes/slots.Thats it. I also got the mounting hardware kit along with a few other things to mount. The only holes drilled are covered by the plastic trim piece.
I used 3 hole 1/4-20 T nuts and some Z nuts to attach the bottom in the slots. Drilled out the outside holes and used the center hole for mounting the plate. Used some rubber washers to protect paint.Great idea - just ordered one. I wonder if butterfly anchor bolts would work to attach to the swing gate? Probably depends on whether the molle panel holes align to the swing gate holes/slots.
Checking on this before I pull the trigger on the JCR table….on the way
on the wayChecking on this before I pull the trigger on the JCR table….
Is this on Amazon?
Looks great, sign me up.Final version, on the way
I tested it and it didn'tWant this but does it make noise rattle when driving?
