Need Suggestions For a 4 Pin Wiring Harness
DangerMTBBronco
Dale
Lake Elsinore, CA
youtube.com
2022 Bronco Badlands Sasquatch
Looking for a 4 pin wiring harness to add to the tow hitch. I'm not towing just need to hook up my bike rack brake lights with 4 pin connector. Going on a Badlands. Appreciate your suggestions and feedback.
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
Curt 56471 for a Base without Led tail lights
DangerMTBBronco
DangerMTBBronco
Dale
Lake Elsinore, CA
youtube.com
Sooner
Ted
Henryetta, Ok
I installed mine Saturday, and added a 4 pin to 7 pin adapter so I coul simply unplug it and have either
HBTFD
Newnan GA
F350
Good luck. When I bought the curt version in December that they advertised as “plug in play” I ended up swapping wires around in the hard shells.
Sooner
Ted
Henryetta, Ok
Mine works fine
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
Curt now has two 4 flat wiring kits. LED and Halogen. The Halogen is the newest offering and is a direct fitment for the Black Diamond.
DangerMTBBronco
DangerMTBBronco
Dale
Lake Elsinore, CA
youtube.com
Yeah I just watched an install video. That's not PIP. Had no clue the wiring install would be such a job. I hate doing wiring stuff. LOL
HBTFD
Newnan GA
F350
I hope it works. I’ll never buy another Curt snything
Hopefully Curt’s latest version is a direct fit.
sgraing1
451xx
Don't hate on me. I'm just the messenger.
I installed their newer and correct offering and used it without any problems.
For anyone that is interested in their two different 4 flat wiring harness kits...... Custom Wiring & T-Connectors
Good Day All !
PCDan
Dan
Park City
1968 Ford Bronco
i installed the Curt harness today. Its super easy to install. Hardest part is running the power wire from the back to the battery. . Plugs into both taillights, connect ground wire to frame and run the power wire to the battery. Not sure how much easier it could be lol.
i also wired the harness plug end into a Hopkins 4/7pin combo plug. Comes with a steel Bracket that bolts to the frame right next to the Curt hitch receiver.(which bolts right to the frame with 4 bolts).
https://hopkinstowingsolutions.com/products/vehicle-wiring-kits/multi-tow/40975.html
HBTFD
Newnan GA
F350
I’m glad Curt corrected the harness to work for you.
PCDan
Dan
Park City
1968 Ford Bronco
Yea no reason to spend 5x for OEM stuff when the Curt hitch and harness works great. And the hitch receiver looks less chunky than the ford one
bigvo9
Everglades
Wes
Boulder
Everglades
Everglades
Good Day All !
Which one did you go with? is the #56471 the newer one?
sgraing1
451xx
56471 For NON LED (Halogen) Lights.
I have a Black Diamond.
Curt 56468 is for Broncos WITH LED taillights.
Badlands uses LED taillights.
