broncorik
broncorik
Maybe Ford got it right on the third try? Oh well...I will just use the max mark on my b-stick as my target for now and not worry about the minimum mark until the f-sticks get us all new f-sticks.
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
Do we know at approx what build date the correct dip sticks ARE being installed at the factory? Thanks
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
What broncorik said. The boneheads released the new batch of sticks with the -B suffix change and when those sold out, decided to change the suffix again to -F. Since these are on backorder "tentatively" until the end of July, I can't tell you with 100% assurance they are identical but will tell you they are identical. This -B to -F change is in suffix only, not a third design change.
Thnx...I would like to order one.
flip
Phil
IN
www.ruxerparts.com
Fords
According to the parts program we use, the new style is used in vehicles built 5/9/22 and later. It's entirely possible Broncos on either side of that date could have the other style just because some build date breaks are not absolutely 100% accurate. The dead giveaway is the old style has an "H" on the top of the pull and the new has a black triangle.
10K_Vet
Ron
Bossier City, Louisiana
2007 Dodge Ram 1500 5.7 Hemi
DUSTYcazOREGON
Craig
Thank you very much!
bytheway
Brice
Louisville, KY
I have an oil change coming up... so is about 1/2 way up the hash mark 7qts? Or do I go to the top of the hash? Where are we sitting on the new stick basically.
broncorik
broncorik
With a drain and a 7-quart fill (and the B or F stick) the oil level (after waiting the recommended 15 minute shut off period) will be below the top hash mark but above the add mark...closer the the top mark than the bottom.
Ts3794
Ron
Reno
Jeep
Late may build,
I have the “H”. And “ -BF” part number
flip
Phil
IN
www.ruxerparts.com
Fords
Late may build,
Ha! I wondered when someone was going to blow that up. Can you get a pic of the engine build tag on the valve cover? I'm wondering if the build date break actually refers to the engine build date. Almost always, the date break is by vehicle build, not component. Going to be even more surprised if your engine build date is after 5/9/22.
Ts3794
Ron
Reno
Jeep
engine
Ef06A22131120402
engine build date. 5/11 if I read it right
bronco Build. 5/22
pics coming soon
flip
Phil
IN
www.ruxerparts.com
Fords
engine
Ef06A22131120402
bronco Build. 5/22
pics coming soon
If we don't have too many more outlier cases this would follow a previous statement, that build date breaks are sometimes imperfect and things like this can happen. We've seen TSBs in the past that specify date ranges for a specific issue and someone come in with that problem but is just outside the date range. This isn't common and can be a PITA to try to get Ford to add the vehicle to the program.
Bigeffr
Manassas VA
22 6G BL SAS - 22 Sport Badlands - 13 F150 Raptor
I have the same stick as TS3794 but my build date was 6/9
