- Jan 21, 2021
- 103
- 366
- 356
- New Orleans, LA
- Website
- www.oraclelights.com
- Bronco
- Base
Looking to add a functional Bronco third brake light or a stylish spare tire ring? Get the look you want with the ORACLE Lighting LED Illuminated Spare Tire Wheel Ring Third Brake Light!
Using our durable aluminum wheel rings and our industry-leading 2835 LED illumination, we offer this popular mod in red for a high-powered third brake light ring or in ColorSHIFT® for RGB control of the ring. This vibrant illumination behind your spare tire is guaranteed to grab the attention of everyone around -- either with a brilliant red brake light or any color imaginable displayed. The red brake light provides more safety and visibility while the ColorSHIFT® option allows you to match your other color-changing accessories.
With a universal fitment, the brake light ring has a 13-inch diameter and mounts to the spare tire carrier. A great-looking modification with real functionality, your trail partner can spot your Bronco a half-mile ahead! Improve your rear brake light illumination and get a customized look with this Bronco spare tire ring.
Transform the look of your Bronco's rear end, and enjoy an easy install of this brake light ring with the provided hardware. The extended brackets mount to the spare tire carrier. The wiring is easy; simply tap into your existing third brake light wire.
Available in RED to tap into your third brake light, or ColorSHIFT which is suggest for show use only.
Reminder to use code FORUM10 for your forum discount at checkout!
Order HERE!
Order HERE!
