- #16
My understanding is that good quality fuel and occasional use of an injector cleaner does not directly help with carbon build up on the intake valves but it does keep the injectors clean meaning they actuate properly and spray pattern remains as designed ensuring good atomization and therefore good combustion, an attribute that seems especially critical in direct injection engines.From my understanding, fuel has nothing to do with the issue. It is that fuel does not pass through the valves, being directly injected into the combustion chamber. This causes the unburned oil, returned through the emissions system, to coat the valves. I am optimistic that the new oil spec will be helpful and a catch can is already a proven process to reduce the problem.
