[New Upgrade] Enjoy 30% OFF on Mabett V2 Dashboard USB Expansion Dock,Now Only $34.99!
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
Hey everyone,
Our V2 Dashboard USB Expansion Dock has just been released. It provides a simple and easy solution to increase the number of USB ports in your Bronco, letting you charge multiple devices simultaneously.
Buy with $34.99 directly through "https://www.amazon.com/promocode/A2QQIYEV0T1YBI", 30% OFF exclusive for Bronco6g. Discount will be applied at checkout.
If you have already made a purchase, you can contact me for a price adjustment refund.
What's New
In the V2 version, we have changed the power supply method. Previously, we were drawing power from the central console, which resulted in unstable voltage and the possibility of being unable to power all three interfaces simultaneously. Now, we have directly connected the interfaces to the USB power source, ensuring a stable output current. Now you don't have to worry about any situations where the device won't charge properly.
About this item
  • Features: With two type C ports and one USB A port, you can charge multiple devices at the same time. No more “low-battery anxiety” while traveling.
  • Fitment: Fit 2-door/4-door Ford Bronco 2021-2024. If you have dashboard rail system, please pay attention to its compatibility.
  • Installation: Using the original screws hole on dashboard, OEM-level appearance quality. Check the video below to know details.
  • Specifications: The USB A ports output 6W, the middle Type-C port outputs 6W, and the Type-C port near the passenger side outputs 15W.
The stock is very limited. Don't miss out this promotion! Order and enjoy the conveniences right now!
Ford Bronco [New Upgrade] Enjoy 30% OFF on Mabett V2 Dashboard USB Expansion Dock,Now Only $34.99! IMG_4417(1)
Ford Bronco [New Upgrade] Enjoy 30% OFF on Mabett V2 Dashboard USB Expansion Dock,Now Only $34.99! IMG_4445(1)
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
Question: If you have the LUX package, and you have a USB C and A up front, by the windshield sensor, will this work with that?
This solution makes it a little easier to add things to the USB.
Tricky Mike
21 Bronco
I'm considering grabbing this, but I'm curious if I can run a circuit directly from the battery and cut/splice the supply voltage wiring on my V1 unit, or has the V2 board been updated as well for the increased current?
mdk100
Los Angeles
Porsche 911, Cayenne, BMW X3e, 2 door BaseSquatch
@Mabett, will this work with the Mabett device rail? Have you checked?
Mabett
Mabett
Mabett
China
www.facebook.com
Yes, sir. It works with Lux package.
Mabett
Mabett
Mabett
China
www.facebook.com
It can be used with our rail mount but the USB A port on the left side will be blocked unless you do some cut yourself.
Ford Bronco [New Upgrade] Enjoy 30% OFF on Mabett V2 Dashboard USB Expansion Dock,Now Only $34.99! 347238730_6998370200193067_7790549468817531586_n
Mabett
Mabett
Mabett
China
www.facebook.com
Mabett
Mabett
Mabett
China
www.facebook.com
The V2 board has also been updated.
Mabett
Mabett
Mabett
China
www.facebook.com
Will a BYOD rail with this the expansion?
You need to measure it yourself. The distance between the two Type-C interfaces is approximately 25.4cm.
Ford Bronco [New Upgrade] Enjoy 30% OFF on Mabett V2 Dashboard USB Expansion Dock,Now Only $34.99! AF35F041-52DF-4130-BAE4-7BEEC0EE9ACB
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
If anyone is having trouble with the link...
30BQYMV7
Type that promo code at checkout for the $15 discount.
swaing
Gary
Belleville, Il
4dr Ford Bronco Wildtrak with Sasquatch package
Hey everyone,
What's New
About this item
Does this fix the low voltage for charging phones? The v1 actually drew power from from my phone rather than charged it. I was looking for fast charging capabilities. Does v2 bring that?
Mabett
Mabett
Mabett
China
www.facebook.com
Yeah, definetely, the voltage is very stable now. The type C ports supply fast charging.
