Next Bronco 7th Gen
kylearmani
Kyle
Houston, Texas
GMC yukon denali
Let's take a break from all the stuff right now and look into the future. What do you guys think is gonna be included on future bronco trims?
NotApplicable
BEVs
Yay the 594th thread about how the next bronco will be an EV
myrealname123
Trent
Monterey, CA
'21 Bronco
There won't be a 7G, how bout dat.
Rusty Sheckleford
America
Ford Escape
My wishlist:
V8 Engine. (duh)
A real tailgate with power rear window
Ford Bronco Next Bronco 7th Gen tailgate-o
A bench seat
Ford Bronco Next Bronco 7th Gen post-15817-12895158655415
A better folding rear bench seat (something to give us more flat space in the rear), that is also easily removable.
Ford Bronco Next Bronco 7th Gen 1027-1
Column mounted shifter
Ford Bronco Next Bronco 7th Gen s-l640
And maybe cooled seats
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Low Hammer
Idaho
10th gen F150
It probably took 5 years and billions to get this generation out there. Therefore I think the current Bronco will be out for quite a while(10 years if I had to place a guess), but probably with a few engine, transmission, and drivetrain changes over time. I suspect half of the current gen broncos sold will end up being plug in hybrids by the end of this run. Most likely the hybrid versions will be comparable in implementation to the hybrid f150 just because that would be the route of least resistance for Ford, but obviously you can't cut and paste an f150 powerplant into this chassis.
As for next gen; technology trends tends to drift from expensive cars into cheaper ones but with more robust and simpler implementations. The ruling class is obsessed with phasing out gasoline so Like it or not it will probably be an electric vehicle first with a lot of features copied from the rivian, the hummer, and the cybertruck. Personally I don't expect the suspension design to change much(conceptually), but 4 motor AWD standard with front and rear steering on a sled frame seems like a given. I suspect there will be a hybrid option, but that the option will basically be a glorified bolted on generator with a small gas tank for an exorbitant fee.
The powers that be want us all riding in leased self-driving 5000lb golf carts. So be it.
The Dmv
D
Louisiana
2021 Bronco 2d Base
Something Ford can deliver on time would be a sick feature.
Compta38
Alabama
Ford Fusion
It will end up as a neutered crossover like the Blazer and it's brand will be forever tarnished. If Ford were smart they would leave the body style alone and make minor tweaks each year, add colors options etc. similar to Dodge Challenger
