Nine door related patents that could apply to 2021 Bronco
vr00m_vr00m
03 Corolla, 93 G20, 87 Bronco II
Various patents Ford has filed.
Analysis: https://www.thedrive.com/news/29607...-ford-has-filed-ahead-of-the-2021-ford-bronco
Interestingly enough Ford is using a variety of models in the patents. One shows the Troller another has the 2004 concept. Also there's a new patent where the climate control senses when the tops are off.
These are the patents so far:
Split-Detachable Door (Patent #US 10272747 B2)
aging%2Fmessage-editor%252F1567014131352-broncosplitdoor.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
This patent covers a door that's split in the middle with the side mirror attached to the lower panel. Notably, the system also allows the window pane to be housed in either the upper or lower half of the frame when they're separated. Solo use of the lower door would be useful "for beautiful days when an open air experience is desired." It's also further evidence to support the rumored convertible Bronco.
Removable Door Cargo Storage (Patent #US 10150420 B2)
staging%2Fmessage-editor%252F1567014184776-broncostorage.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
Ford's patent here is the answer to every Jeep Wrangler's least favorite part of open-air motoring—stashing the doors. The solution involves a special carrier for the lower door panels to bolt into located in the cargo area. The main issue we see is that it's based around the split-door design and doesn't have space for the upper frames. Also, only a four-door setup is depicted; it doesn't look like this would fit in the two-door version's smaller cargo hold.
And lest you think the Jeep-like truck in the sketches is a leaked Bronco, it's not—it's a Troller T4, the Brazilian equivalent of a Jeep Wrangler whose manufacturer is owned by Ford. What is important is that Troller doesn't make a four-door, so this is clearly supposed to be a stand-in for something else. Companies often use placeholder vehicles from their portfolio for these drawings in lieu of exposing a secret design.
Folding and Detachable Suicide Doors (Application #15/822523)
ing%2Fmessage-editor%252F1567014156425-broncosuicidedoor.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
This is where things get a little weird—and interesting. Building off the idea of a split door where the lower half represents a compact, nearly-rectangular panel, Ford's been thinking about how best to store it. One idea is this reverse suicide setup where both the front and rear doors are hinged on the B-pillar so they swing toward each other. When the two lower panels meet, they can be bolted together and stored on either a tailgate or roof rack carrier.
Retractable Door Opening Restraints (Application #15/898312)
2Fmessage-editor%252F1567127263661-retractablerestraints.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
The idea here is for a safety rail (or two) that spans the door frame from the A-pillar to the B-pillar when the regular door is off. Ford describes either having them extended at all times when the door is off, or having them automatically extended when the vehicle senses a crash is imminent. They would also be capable of holding an airbag like the tube frame door described below.
Tube Door Airbag Inflator (Application #15/899000)
taging%2Fmessage-editor%252F1567014040416-broncotubedoor.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
Ford’s been thinking about how to provide side airbag protection without a door. The patent application includes a few setups, including a removable tube-frame door similar in design to that of a UTV. But Ford’s increased the theoretical safety by using the tubular structure to house high-pressure gas lines and an airbag inflator. Another scenario covered by the application includes a telescoping rod that shoots across the doorless opening to deploy an airbag in the event of a crash. Flip through the PDF and you'll notice one of the sketches bears a strong resemblance to a first-generation Bronco.
Detachable Outer Door (Application #15/882882)
staging%2Fmessage-editor%252F1567014100218-broncobardoor.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
Ford’s patent shows that the Blue Oval is looking at skinning a tube-frame door structure with a detachable panel to retain the normal body lines. It would look like a normal door, but remove the outer skin and you’d have the cage-like, open-air inner structure.
Flexible Door with Airbag (Application #16/246488)
ging%2Fmessage-editor%252F1567014116438-broncofabricdoor.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
Ford cribbed from the world of UTVs once again with a patent application for a flexible canvas-style door and integrated airbag that's zippered or snapped into place.
Doorless Side Mirror Lighting (Patent #US 10166913 B2)
-staging%2Fmessage-editor%252F1567014217614-broncomirror.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
This one is more a statement of purpose than anything else, but it shows that Ford has already thought about how to maintain the proper side illumination when the door is removed. The mirrors are mounted on the A-pillar, so their mini-floodlights can still illuminate the ground with, say, a bucking bronco even when the doors are far behind. Again, the vehicle in the sketch is a Troller T4, not the so-called Baby Bronco that's coming... though honestly, we wouldn't mind it if it was.
Doorless/Roofless Climate Control (Application #15/876784)
staging%2Fmessage-editor%252F1567014235413-broncoclimate.jpg?auto=compress%2Cformat&ixlib=js-1.4.jpg
Lastly, Ford applied for a patent for climate controls that would sense whether or not the doors and roof have been removed for an SUV.
Again, there's no way to know which of these, if any, will make it to the production 2021 Ford Bronco. All we can say with certainty is that Ford's been thinking a lot about how to make removable doors a reality. We'll keep our eyes open for any more Bronco-related patents documents in the weeks and months ahead.
Advertisement
Stampede.Offroad
SD
junk
They found a couple new ones. The use of sensors to deactivate some climate control features with doors/roof off certainly seems like a practical one.
My favorite caricature is the pickup that looks like it was drawn by a 5 year old.
Simmy
NW
All American
I like the door carrier idea. Never have to decide whether to take doors off before leaving home. Hopefully that means the doors will be easily removable on the fly.
Stampede.Offroad
SD
junk
https://www.motor1.com/news/369107/ford-bronco-roof-grille-patents/
There are a couple more roof and grille patents too. Showing the “air roof” possibly??
Now here is one that could be interesting. The roof seems modeled after the Troller, but the grille shows a touch of something I've seen in the tarped image ...
The hood appears to have the ridges left and right like an EB, but in the middle it could be pitched downward forward of the axle to aide visibility. The far right grille segment shows a similar slope. Or maybe its the shape of the mustang, who knows.
The Ford Bronco Will Be Revealed In...
Similar threads
