Non B&O stereo wire harness to add aftermarket amps
LeeT
Lee
Pennsylvania
2024 Wildtrak
Hello everyone.
I have been searching this forum and even messaged Hoel wiring several times with no response.
Please point me in the right direction.
I would like to purchase a pre wired harness for my wildtrak with the 7 speaker system. The wire harness would need the factory speakers to remain running off the factory amplifier. I need wires tapped into the front channels so I can put a LOC to run my aftermarket amps.
Everything I see is for the kicker key which is not what I am looking to do.
Is there anything out there for what I would like to do. I appreciate any help. If there is something out there ready to go can you please post a link. I have had no success finding what I need.
Thank you for your help.
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S
Hello everyone.
Can't you just use this and finish wiring to/from the amps yourself?
https://hoelwiring.com/products/ford-maverick-diy-plug-play-audio-harness
LeeT
LeeT
Lee
Pennsylvania
2024 Wildtrak
That's one of the messages I asked them. I just want to be sure that I order the right thing. Would this allow me to keep the full range speakers running as they do now and also take the signal from the fronts to add the amplifiers?
I got the generic harness from Crutchfield, but it required splicing. Im sure a PnP harness is out there but depends on where you are putting the LOC and what the inputs look like on that… so may need to be a custom job or one designed for another amp that could work anyway
motiv8dRN
Edwin
Cordova,TN
2024 Ford Bronco
I upgraded my 24 OBX and used the harness from Crutchfield and it works flawlessly. I’ll attach pics.
Ford Bronco Non B&O stereo wire harness to add aftermarket amps IMG_7371
Ford Bronco Non B&O stereo wire harness to add aftermarket amps IMG_7370
Ford Bronco Non B&O stereo wire harness to add aftermarket amps IMG_7372
HPNQ420
Wauwatosa, WI
You should be able to cut the appropriate wires to the speakers and add a circuit to your amps by joining the factory to wires, from wires, and the wires to your amps. How well it works will probably depend on the current draw from your amps.
motiv8dRN
Edwin
Cordova,TN
2024 Ford Bronco
If you just want to get a signal to send to your amp (I.e., connect to a sub) there’s a jumper included that doesn’t affect your speakers. Hope I understood your question.
MWARD1733
Memphis
2024 Bronco Heritage
I just sent you a message
