NORMAL G.O.A.T. Mode — 4A, 4H or 2H?
Gtrekker
Gary
NJ
I didn't know that there was a speed limit in 4A. I drive in Sport mode often which sets 4A by default. Is there a way to run in Sport on 2H?
Yes, once in sport mode push 2h.
LiftedPony
Sean
Irvine, CA
2021 Wildtrak 4dr, Porsche GT4, Porsche Macan GTS
I got more clarification on this as my rig was spec with "Advanced 4x4 with Automatic On-Demand Engagement" and when switching to Sport (where it auto selects 4A) is safe and does not cause damage or have a max speed limit for usage. It will be an issue with rigs that are spec with "4x4 with part time selectable engagement".
Previous thread about this: https://www.bronco6g.com/forum/threads/advanced-4x4-vs-the-standard-option.9201/
https://www.ford.com/suvs/bronco/mo...anced-4x4-with-automatic-on-demand-engagement
Ford Bronco NORMAL G.O.A.T. Mode — 4A, 4H or 2H? 47517F75-7054-411D-97CB-606C2301973D
Dmorty217
Derek
Venice FL
Camery
Dont see
Auto in there
There isn’t and if you read above where I posted I clarified that. My point was if auto kicks into 4 at 70 mph it’s 4H right? That can’t be good for 4 wheel drive
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
4A and 4H are two different selections meant for different driving. Advanced 4x4 models have 2H, 4A, 4H, 4L. 4A safe for pavement at highway speeds.
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Shouldn’t be driving over 70 and shitty weather anyway so keep it under 70 and Auto should be all good?
Dmorty217
Derek
Venice FL
Camery
Good to know, I don’t have the fancy package so I’m not familiar
Rjacks258
Randy
Punta Gorda, FL
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
I don't think Normal will automatically select 4A; should always be 2H to start.
I think that is how mine has been working, Normal-always 2H
Until I hit the
4A button on the Goat dial
More specifically… keep foot on the throttle hit 4A, let off for a split second, the solenoid clicks….then resume speed,
71to21-2DR
Rick
Lincoln Ca.
Nissan Frontier 4WD
Is there a way to shut that off somehow, so I dont wear the button out always putting it back in 2Hi in sport mode?
Let me guess? Forscan only??
Gtrekker
Gary
NJ
I don't have an answer for that. There are some sharp forscan folks that would know. GL!
