NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS
TheShark
'24 Bronco 2DR Heritage Edition Limited,'25 Maverick Lariat Hybrid AWD
Ford dealer installed them. Look great! Everything works but they don't fit as flush as the OEN mirrors backs. OEN has a fingernail width gap witdth is how they should fit. The Oracle mirror-mounted ditch lights have about a 4 fingernail gap all around both mirrors left and right....like they are not snapping in deep/flush enough. Is there a seal that was supposed to cover this gap? Or did I receive old stock and the mold has not been corrected so they fit more sung/flush?
Mine unfortunately fit the same and it's really the driver side that is the worst of the two.
FFF
My driver's side is more off than the passenger side. I took pix but am trying to learn how to post them for the kind gent from Oracle who responded trying to help.
TheShark
I'll be curious to hear what Oracle has to say.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Typically if the perimeter edge is not sitting completely flush it is because the housing is hung up around the side camera and just needs to be snapped in around the camera before snapping in the perimeter clips.
TheShark
I've had the drivers side off several times trying to reseat it but end up with the same amount of gap. The passenger side fits fine and since other people have complained about the same drivers side fit I'm guessing it's a problem with how they are molded. When I was at the Bronco Super Celebration last year I even checked out a few Bronco's with the ditch lights mirrors and all had the same issue. At least I knew it wasn't me or how I fitted them.
Gotchaa
Los Angeles
Tesla
these molds were never fixed, Oracle did not go back and revise them, don’t’ expect them to fit perfectly. You will need to Dremel around the camera area slightly to get them on right. Message Oracle and they will tell you the same. I brought this up when it was first released and it sounds like they never went back to fix it. If you want a perfect fit, this is not for you.
