OBDII reader / scanner recommendations?
88to21bronco
Tennessee
2017 Nissan Titan XD
Disclaimers:
1. Yes I have searched this forum. There are several threads that mention OBDII readers, and this one is extremely interesting.
2. Yes I know they are all over Amazon.
So my question: Which readers would you recommend? For quality, value, ease of use (I'm an IT guy, but new to auto stuff), and versatility. I want to access onboard stuff to change, as in the above link. And calibrate speedo once I upgrade tires/wheels, read codes, etc...
And I know there are app options for phones. Any guidance there would be appreciated, too.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
I have the port adapter and app from FourStroke for my iPhone, seems to work well for data read out and resetting error codes. It is not a programmer as those are much more expensive (I also have a SCT to tune my Ford V-10)
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Been using a Scangauge II for 14 years on my current rig. It does almost everything I need it to other than trans temp due to the way Nissan locks it out, I believe they have cleared this hurdle though with x-gauges now. It does adjust for larger tires which was my key need other than reading codes. I am in IT too and its totally plug and play. Doesn't have the prettiest of displays but the thing just works.
Razorback
Bill
Dallas
Lincoln MKX
Inquiring minds want to know. 👍 I've been researching and FIXD makes one that looks pretty cool.
jalexa27
James
Excelsior, MN
1965 impala
Disclaimers:
Depends on what you want to do. I just downloaded Forscan and use the OBDLink EX cable. It gives you the ability to unlock since hidden features. May be a little more expensive than other options.
JesseS
Jesse
Northern California
I just did that myself after reading up on it, got the OBDLink EX on Amazon for $50, already have a Macbook Pro with dual-boot and Win 10. Will have to spend some time learning the layout but looks simple enough.
88to21bronco
88to21bronco
Tennessee
Thanks for the responses everybody. I'll try it out when (if) I ever get my Bronco.
2Jeeps&PatriotX1
Denver, CO
Have had the OBDLink MX Bluetooth and its done everything I've needed the last 3 years.
Greasyfingers429
Adam
RI
VW Jetta TDI, Range Rover Sport Td6
I just plugged in my ScanGauge II for the first time in my 2021 Bronco, after having used it since my 2006 F-350 and ‘13 Jetta TDI. The standard gauges mostly work by default. I have decided this device is mostly obsolete. Everything from mileage, temps, boost, etc are mostly available right in the dashboard gauges screen, if you turn it on.
What I can’t figure out are any of the customizable ScanGauge X-Gauges. So far, there is zero support on the ScanGauge website or web search results for the 2021 Bronco. I might look into one of the more modern devices listed here in this thread, hoping to get engine torque, torque converter slip, and especially EGT pre- and/or post-turbo.
The one feature ScanGauge should be able to report is adjusted speed if you run larger tires, but I bet there’s a more elegant solution to reprogram the actual speedometer for that too.
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
