I'm sure a good aftermarket unit will be out but ford is offering everything under the sun why not a bike carrier ?
Way too much liability and take rate would be very low.I'm sure a good aftermarket unit will be out but ford is offering everything under the sun why not a bike carrier ?
Will be fine for dirt bikes.Aftermarket already has you covered and it'll be too heavy for the rest receiver.. The Bronco isnt rated to carry enough, or barely. 10% of tow rating for hitch weight is 350 lbs.
Plus one for the MX hauler. I have a class III hitch on my Subaru Crosstrek and carry a Husky 501s. It is way over the tongue weight rating for the Subaru but so far has been OK. I think the MX hauler is around 50lbs and my Husky is around 300 so 350 total is the tongue weight limit for the Bronco. One potential issue with the Bronco is the external spare tire. Using a hitch extension is a no-go because it would half the tongue weight limit due to leverage. Ideally the MX hauler+bike would fit with the spare tire but I doubt it. My hope now is that I can remove the spare tire and can fit the bike around the remaining backup camera and spare tire mounting hardware but who knows. I am going to be massively frustrated if I can't find a good way to haul my bike on the Bronco since I can do it on the Crosstrek even though I am exceeding the tongue weight limit.Way too much liability and take rate would be very low.
MX Hauler will work fine.
MX Hauler is 60 pounds.Plus one for the MX hauler. I have a class III hitch on my Subaru Crosstrek and carry a Husky 501s. It is way over the tongue weight rating for the Subaru but so far has been OK. I think the MX hauler is around 50lbs and my Husky is around 300 so 350 total is the tongue weight limit for the Bronco. One potential issue with the Bronco is the external spare tire. Using a hitch extension is a no-go because it would half the tongue weight limit due to leverage. Ideally the MX hauler+bike would fit with the spare tire but I doubt it. My hope now is that I can remove the spare tire and can fit the bike around the remaining backup camera and spare tire mounting hardware but who knows. I am going to be massively frustrated if I can't find a good way to haul my bike on the Bronco since I can do it on the Crosstrek even though I am exceeding the tongue weight limit.
Except that is not is what this thread is about.Everyone brings up excellent points so far. I think the safest, and easiest option to implement without messing up your backup camera view or spare tire, is to get a $700 trailer to tow behind. Added bonus is you'll be able to fit two dirt bikes, gas cans, and coolers
And then you'd have to store it. Pass.Harbor Freight sells a trailer for $300 (definitely less than the Versahaul). You'd have to add a sheet of plywood. So, there are probably less expensive and (in some cases) better alternatives than hanging a bike on the back of the Bronc. And, you'd have, as the other poster stated, a place for fuel, tools and gear.
