Minnesota OEM Parts access "Repair Link"
Schwaggle
Robert
Scandia, MN
2021 350 Tremor, 2002 Excursion 7.3L
I just wanted to open a thread giving access to everyone part numbers and your local dealer costs.
Repairlink parts access
1) Towards the middle of the page on the left, click on: "Shops Register Now"
2) Fill out the "Shop Registration" page; whatever you want your "company" to be named
3) Once that's all filled out, it should bring you to the "Add Dealers" page. The 3 important ones are: "Select OEM," (which you can add multiple manufacturers like Chev or Isuzu, etc.), "Dealer," (you have to add some letters to find the dealership you're looking for, and yes you can have multiple Ford or whoever dealerships), and your "State." It's easiest just to type in the manufacturer you're looking for into the "Dealer" box, i.e. Ford.
4) Once you're selected the dealerships you want to have access to, click on the "My Dealers" drop down tab, and select the "Dealer List." and select one "preferred" for the brand you are most likely to deal with. Once you've done that, up at the top you can fill out the manufacturer/year/model, or just fill out the VIN, and click on the "Search" box.
5) Finally, once you have found the parts illustration you're looking for, click on the "callout" number, and a list will change to the part description on the right. In order to see the full P/N and pricing, you will have to ADD IT TO YOUR CART, then go to your cart, and you'll see the full P/N and your dealer cost.
6) lastly, if you did NOT provide a VIN, you will get a lot of drop down option boxes where you will have to select special packages, like 3dr, 5dr, or don't know, show all. Show all is good for, let's say seat covers, where there are a lot of different options, like onyx black, leather, #3 or #6 and aren't easy to figure out which is which. You'll get a lot of options when you select a seat cover part on the right hand side, with more specific information to select what you want. Play with it and see like 95% of what the dealerships can see. Also printing off the cart (which if you have multiple pages in your cart, like over 10 parts, you will have 2+ pages), you will have to print each page separately until they fix it. This gives you price matching when you go to the parts department if they're asking more than what your pages show.
Any questions, just PM me
Happy shopping!!!
Funkdoobiest
Buffalo
Ford Bronco Basesquanch First Edition
Thanks!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Schwaggle
Schwaggle
Robert
Scandia, MN
redone17
Cold Spring, NY
Schwaggle
Schwaggle
Robert
Scandia, MN
Seems fishy…to anyone else?
Ahhh.. I've been using them for years for work, and while looking up parts for this forum I tried and found that you don't need to be an actual shop, so I spread the word of parts and breakdowns. This was my go-to for light duty fleet of Metro Transit Econolines. Afraid to use it; then don't. It has advertisements on the top or bottom of the screen, but my Ford parts guy moved companies over the winter so his login doesn't work anymore... and this is whats I's gots
redone17
Cold Spring, NY
Well, thanks then! I’ll check it out. I’m sure @flip will appreciate a bunch of us no longer annoying him. Haha
Schwaggle
Schwaggle
Robert
Scandia, MN
Dude has WAAAAAAAAAAY better access than me; but 95% of the parts book is still 100% better than nothing. BTW: While he found the Raptor grille, Raptor/Everglades parts have not yet populated in Repairlink as of today...
I never have nor will work for Ford, since I'm a fleet mechanic; but you know enough people in the business and logins get exchanged as well as access to other venues for parts; so somehow part sales go up and I get the right parts the first time...
I have '94 + Fordserviceinfo creds, but I will never publicy share that; don't bite the hand that feeds.
redone17
Cold Spring, NY
Wow. I take back my hesitation. This is so helpful. Thanks for the heads up.
Schwaggle
Schwaggle
Robert
Scandia, MN
Well, most of us are on here trying to help lol. Adverts aren't even ridiculously annoying, unless you have to reselect another model at the top.
Also, save your cart often! It will save different carts for the same vehicle selection, so if your cart goes to 0, load your last cart to get all of your P/Ns back.
One more issue I've had lately: if it takes forever for the parts list to populate on the right side, like when you can't select a part, log out then back in, and select your saved cart and start looking for what you wanted to find again. Hope that saves you 3 hours of frustration lol
flip
Phil
IN
www.ruxerparts.com
Fords
Ford allows us to give wholesale customers access to the technical information system which is a good thing. Repair link, OE Connection are the avenues shops submit orders, look up parts and check inventory. I don't see the issue with allowing access to find parts or look them up with the exception if they are doing so to cross to aftermarket. Obviously, Ford would want you to use their tool to look up and purchase Ford parts. The more info out there, the better for consumers, shops, dealers and Ford.
Schwaggle
Schwaggle
Robert
Scandia, MN
I couldn't have put it better myself. Part of the reason I converted the family to the Blue Oval; that and Ford's part numbering system makes sense in my head: vehicle-module-version/special part
