johndeerefarmer
'17 F150, '20 F350 Powerstroke
But I'm in agreement against the turbos. It is the one nagging fear I have about the Bronco, getting a tiny engine with a high RPM, red hot jet engine stuck on it to make decent power. How long will it last? If I have to buy a new turbo or even an engine in 5-10 years, the expenditure will be very disappointing. When my old normally aspirated engines run for decades if you keep oil in them.
First of all it's not a high rpm engine. It delivers torque low down like a diesel. My 3.5 EB never sees 2k rpm unless I have the pedal down hard. Towing rpms also stay low like a diesel. When Ford added port injection that took care of the problems that it had with carbon build up. The engines are very reliable unless you put a hot and unsafe tune on it.
I have kept several John Deere tractors for 15 years and had no turbo issues. As a matter of fact I have had turbocharged Deere's since '92 and never had a turbo issue so I wouldn't expect a turbo failure in an ecoboost unless you are stupid and don't let it cool off before shutting it down. The 3.5 EB continues to siphon water through the turbos to cool them after you shut the engine off but not sure about the 2.7. Either way I always let all of my turbocharged equipment cool down before shutting them off
dgorsett
colorado
F250, Mustang, Explorer
This popped up on FB, from Cabela's, $215, 15 gal. Might be one solution. Couple issues: How do you mount it high enough to fill your Bronco, and how does it handle heat/sun exposure (I've had issues with portable metal containers before)
Ford Bronco Official EPA MPG Mileage for 2021 Bronco posted on fueleconomy.gov 1623177287857
AZshot
Desert Southwest
Vintage Motorcycles, F-150, various other
Someone can build a lot better gas tank than that, there are already marine companies that do. There just has to be a place underneath to fit it.
