Oil Change Requirements 2.7 -- stick with every 5k miles?
Mvruggink41
Mitchell
Port St. Lucie, FL
Waiting on Wildtrak Bronco Sasquatch
Hey Friends,
I have a 2022 Wildtrak with 2.7 and I have 4500 miles on it. Looks like I need a tire rotation as well. So I was planning on doing them. Both within a week, although I pull up my “ford app” and it states I have 50% oil life remaining… Should I still with the every 5K rule? Is there requirements with the factory warranty that I must follow to keep my warranty in good standings. If I can wait, I will wait but I do not want to do anything wrong.. Thanks for the help in advance!
Cheers
  • Like
Reactions: Cat
GloNDark
Reno NV
1973 Bronco Ranger & 2021 Bronco First Edition
The service guy told me 10k is what the oil life calculator goes by.
I plan on changing mine every 5k miles. It's cheap insurance in my opinion. I like to have fresh oil in my turbo cars.
Mvruggink41
Mvruggink41
Mitchell
Port St. Lucie, FL
Thanks for the info, I had any issues I want to make sure I am doing the correct service on it! Thanks again!
JRock17
Justin
Jersey
Ice Mountain 4dr Wildtrak
Do mine and my wifes navigator every 7500 miles, never had an issue….
Razorback
Dallas
Lincoln MKX
I do oil and a 5 tire rotation every 5k. Like Mitchell said above, it's cheap insurance given the twin turbo set up. Plus I enjoy just crawling under it and tinkering. I will let you know that Discount Tire will do tire changes for free, so I set an appointment and then run by there to let them do it...
Mvruggink41
Mvruggink41
Mitchell
Port St. Lucie, FL
Sweet insight on the tire rotation! I will be smart and get it changed thanks everyone for the tips!
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
I ran 10,000 intervals in Toyota trucks for years. It was a bit lighter oil and they were not direct injected engines. I never had a problem.
I will say, my Bronco and perhaps most Ecoboost engines have a fuel dilution issue. The oil at 4,000 miles noticeably smells of gasoline. At 7,000 miles, it is quite dark and exhibits further fuel dilution. I don't think I will let one get that bad again so I probably will be unable to test.
I will admit these are probably within spec and I am probably fine to run it to 10,000 miles for the next 150,000 miles. Changing the oil between dealer trips takes approximately 15 minutes and it is the easiest oil change of any vehicle I've owned.
Jazer
Jessica
2.7 OBX
The service manager at my dealer recommended every 5k. I planned to do this anyways after the first two oil changes being done early.
Bronco21fan
Angelo
NewJersey
Hey Friends,
Cheers
I always changed my oil every 3000 miles and rotate tires make sure you rotate the spare in the rotation
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
Hey Friends,
Cheers
I change mine at 5 because of tire rotation and experience. The eco boost motors tend to have less issues using that interval compared to the ford interval after you cross 100k. I talk a lot with my service department and they are constantly seeing high mileage issue with the 10k oil change.
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
I’ve successfully pushed down the oil change cost to $30, including a full Kirkland synthetic and oil filter. At this point, to do the process every 4,000-5,000 miles is self care.
da_jokker
Jeep Wrangler JKUR
I don10K oil changes on my vehicles, backed up with Blackstone.
However with that said, the Bronco is going to get 5k changes. With being twin turbos, it is going to be harder on the oil.
I just can't do 7,500 to hard to keep up. With numbers like 5 and 10, even my wife can tell when she needs an oil change.
Brockdog12
NTX
2022 Explorer ST-Line
I have the 2.3 and change mine every 5000 miles. When I had my 2.7 F150 I’d let it drain for at least 25 minutes as per the TSB, does this apply to the 2.7 Broncos as well? Just curious.
