- Beefcake
- Dec 30, 2021
- 125
- 282
- 111
- Cincinnati
- 2021 Bronco
- Big Bend
Stage 1 ecoboost kits for the ford bronco are now available from @whipplesuperchargers! The boost in power is real with a gain of 90ft-lbs of torque which is ideal for them larger tires and heavy aftermarket bumpers.
50-State Legal
91 Octane or Higher
Bolt-On Performance
No Modifications Needed
Whether your cruising, off roading, towing or just like to burn the tires, the Whipple cal is designed for all applications. The kit also features revised pedal mapping, increased speed limit, updated shift points, updated shift schedule and deactivate the annoying auto start/stop feature. Each drive mode is maintained, leaving you all the potential options your Bronco was equipped with.
The Whipple Mega Cooler offers 58% greater internal core volume, 144% increase in external fin surface and 12% less restrictive than stock intercooler core. The robust, TIG welded bar and plate intercooler features offset fin on both the cold and hot side, allowing for increased cooling capacity while fitting into the stock packaging. Test show an amazing 32 degree (F) drop in temperature just on the dyno during back-to-back runs, yet even bigger gains are shown during real world applications. The colder air allows increased spark advance and more O2 to the engine, resulting in more consistent power while maintaining safety.
Only 50-state legal performance kit for the new 2021 Ford Bronco 2.7L Ecoboost. Up to 90TRQ/50HP* peak gain over stock using 93 octane.
Whipple Stage 1 Upgrade Kit (2021 Ford Bronco 2.7L) EB-8180
