Optional " High Clearance Suspension "
Glcmranger
Dan
Jeep Wrangler 2-door
Saw that an option on the Black Diamond model titled "High-Clearance Suspension" within the "Power and Handling" sub section of the "Key features" section for that model. Big fat question for Ford. Is the "High-Clearance Suspension" the same as the Sasquatch suspension in terms of lift height and fenders?
Advertisement
perfectburrito
Gil
Maryland
VW Tiguan
Not likely, what I've read is that the Sasquatch suspension is specific to accommodate the 35s.
Glcmranger
Dan
If that's the case, then why have an option related to tire clearance and ride height which a "high-clearance" option suggests? Ford would then be offering an option that does something other than providing the necessary clearance for larger tires such as 35 inch, which in itself is an option too? How would one get an answer from Ford on this subject?
Big thanks for your response.
Used2jeep
Massachuvian
2007 Crown Vic P71
Deleted member
Guest
The High Clearance Suspension is listed as being part of the Sasquatch package which includes the following:
  • 17" Black-painted aluminum deadlock-capable wheels
  • 35" LT315/70R17 BSW MT tires
  • electronic-locking front and rear axles
  • 4.7 Final Drive Ratio
  • High Clearance Suspension
  • Position-sensitive Bilstein shock absorbers
  • High Clearance Fender Flares
da_jokker
Jeep Cherokee XJ
This forum seems to think there are 3 suspensions.
1) High Clearance - Comes with SAS only and the consensus is it like a 1" lift. The Option you see is not stand alone.. it's optional SAS.
2) Badlands Suspen - In light of recent news, sounds like this is HC + Bash Plates + Disconnect. Does not have the infamous 10mm stopper because it has smaller tires.
3) 2" Lift - still don't know where folks are getting this from. Some people reference the Frankenstein Orange Bronco for the debut that has so many non-factory parts on it including the rear axle.... but wouldn't be the first time I was wrong.
Deleted member
Guest
@da_jokker, I'm not arguing with anything you said as you you could be 100% correct...but I do think it is premature to categorically state what is available only with the Sasquatch package and what is available as a stand-alone option. The Ford website is vague.
For example, the High Clearance Suspension. Ford's website list this in the under the Optional tab. Does this mean it is available by itself or does this mean it is only available within the Sasquatch package? The website does not make this clear on way or the other.
Until Ford makes the build and price tool available to us, this is all speculation at best.
MaverickMan
Shane
I hope i can get my Diamond with high clearance, steel wheels, lockers, the good dampners, rubber floors, and a 4.7/MT. Flares, alloy wheels, and tires I couldnt care less. Im getting swampers, bias ply tires like steel wheels, and no flares can tame swampers.
BuckeyeinNV
Matt
Henderson NV
4Runner
They mixed the parts of the Sasquatch package in with the rest of the options on the trim pages. For example, it also lists 35s as an option with no qualifiers, even though we know for sure those require Sasquatch.
The "compare models" pdf appears to be more reliable, and list high clearance suspension as part of Sasquatch. Also, "HOSS with Bilstein Dampers" is essentially the high clearance suspension, and is listed as "available with Sasquatch" on the chart.
Glcmranger
Dan
Please. Spell out all your abbreviations. "SAS" means Special Air Service to me. I'm sure you don't mean that. Help?
BuckeyeinNV
Matt
Henderson NV
4Runner
That's called the Badlands.
da_jokker
Jeep Cherokee XJ
oh I agree... should have posted with a disclaimer :).... my point just being is that most seem to agree that the site lists individual components as optional, but we are 99% they mean with an entire optional package.
SASQUATCH SASQUATCH SASQUATCH ,)
Advertisement
fifteen52
Advertisement
