mdk77
BM
Illinois
Bronco Base SAS
Just got these delivered:) Installing now. I’ll post photos once finished. 😎
Finished. A few conference calls in between the install, but pretty easy. Maybe 1-2 hours. Connected them to the aux switch wire in the front under the hood, but will probably end up just going to the parking lights. Overall… very pleased! I think they are at the perfect level of brightness. Not too bright like everyone says about the white.
Here’s a daytime photo.
This is awesome. On the Aux hookup, is there a pre-wired harness under the hood for Aux or do you need to run wires into the cab? I am a novice here so just trying to understand what I am in for.
SASQTCH
Justin
Oklahoma City, OK
If you got the aux switches as an option they will be under your hood. Or you can pop out a head light and tap into the bottom left wire (with the headlight clip on your right side). My wire was green with redish stripe. This wire is your parking lights and if you tap into it the letters will light up when your headlights turn on.... and they will turn off when your headlights turn off.
mdk77
BM
Illinois
Bronco Base SAS
Ford Bronco Oracle Lighting Amber Black Illuminated Grill Letters Installed pin 9
Thank you!
Broncodude787
Josh
Man it looks great can i get a link to purchase them??
Dirty Bronco
Brad
Charleston
2021 Ford Bronco - 4 Door Badlands
I'm circling back to this to make sure I fully understand correctly. So with the way you have this wired above the letters turn on automatically when it gets dark (via the headlights automatically coming on). But you don't run them at all during the day?
SASQTCH
Justin
Oklahoma City, OK
That’s is 100% coreect
Marauder
Josh
St Louis
MrGreen55
Kyle
Oregon
toyota scion xb
[/QUOTE]
So if I'm reading this right all I have to do is pop out one of the headlights to tip into them? Which headlight's do you have? Video would help.
SASQTCH
Justin
Oklahoma City, OK
I searched you tube for “how to remove bronco grill” and “how to remove bronco headlight”.
Another member here tapped into that wire and provided the wiring diagram.
Both the standard and signature headlights have the same plug and same wires. The headlights can be swapped plug and play.
