ORACLE Lighting: OCULUS BI-LED Headlights for Bronco
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco ORACLE_Lighting_Bronco_LV_Area
Take a look at the Oculus™ Bi-LED Headlamp system for the 2021+ FORD Bronco by ORACLE Lighting. Featuring a unique modular design, easy plug-and-play installation, and advanced LED projection with 5,200 Lumens of high-quality illumination for enhanced driver visibility in all weather conditions. The Oculus headlight is compatible with both the standard and signature Bronco lighting models.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco 1668800503461-
Features:
Precision LED lighting projector for optimum light distribution and beam angle. Installs using original mounting hardware and headlight wiring is Plug & Play into the factory connector without additional relays or harnesses. Halo is available in White, Amber LED, or Switchback Style (meaning white and amber) and features over 200 bright LEDs for a vivid lighting impact.
Benefits:
These all-new headlamps provide enhanced driver visibility with increased and focused LED light output. This complete headlight replacement features a high-precision sharp cut-off line which reduces glare and prevents blinding oncoming traffic even when installed on lifted Broncos. Package includes tool for easy beam angle adjustability.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco oracle_oculus_rendering2_1024x1024-
Modular Design:
The new modular design allows separate components (turn signal, marker lights, and mounting tabs) to be installed independently. This modular design provides smaller packaging size for lower shipping costs for the end user and prevents possible damage from shipping on these components. The modular design also allows for these individual components to be replaced or upgraded down the road when future options are available.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco 2022-08-01_at_3-31-07_pm_1024x1024-
Reliability:
It is undeniably important to implement proper thermal management tools for high-performance LEDs to operate with reliability in various environments. Oculus utilizes both active and passive cooling methods to sustain low LED temperatures. Remote mounted heat sinks and an internal cooling fan work in conjunction to insure proper temperature control and longevity of the LEDs.
Safety:
Light focus is very important for not only driver safety but others on the road who can potentially have their vision obstructed by glare. This is especially significant on lifted vehicles where the light source is raised and, in a position, to interfere with the field of vision of other drivers. These new Oculus headlights feature a very sharp cut-off line and focus light with precision specifically to avoid such issues.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco main_amber_oculus_amber_light_bar_1024x1024-
Product Specifications:
- Headlight Wattage: 36W Each
- Total Lumens: 5200LM
- Headlight Color Temp: 5500K (Pure White)
- Halo Color: Optional White or Amber LED or Amber/White Switchback
- Certification: DOT SAE 5839-504 HL VOR 19
- Patented Design: USPTO Patent D 877,404
- Designed and Developed in the USA
- Warranty: 2 Years
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
Tell me more about Switchback style. How/when does it switch between amber and white?
I.Vegabond
Brittany
instagram.com
Subaru Forester
These are definitely one of my favorite lights I've add to Vega. If you are looking for something to help you standout - these are definitely it!
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco IMG_5615
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco IMG_4910
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Our precision BI-LED Oculus projector headlights deliver optimum light distribution with a sharp, controlled beam angle. ✅ Installs seamlessly using your original mounting hardware—no extra relays or harnesses needed! Just Plug & Playdirectly into your factory connector for an effortless upgrade.
🔥 Plus, the Halo DRL packs over 200 bright white LEDs, creating a bold, eye-catching look on the road. Ready to step up your lighting game? Let’s talk!
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco ORACLE_Lighting_Bronco_Lights_on
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
OracleLights
New Orleans, LA
www.oraclelights.com
Looks that intimidate. Lights that dominate. 🔥
Offered in:
🔵 ColorSHIFT: RGB technology that lets you change your light color to any shade with the push of a button—perfect for show mode and stand-out style
⚪ White: Clean, bright white light for maximum visibility
↔ Switchback : Dual-function LEDs that switch between white (DRL) and amber (turn signal) for added safety and sleek styling.
🔥 Heated Lens: Built-in heating element that prevents fogging, frost, or ice buildup—ideal for cold conditions.
Ford Bronco ORACLE Lighting: OCULUS BI-LED Headlights for Bronco 54487782765_188bb849ef_k
