- Jan 21, 2021
- 168
- 609
- 501
- New Orleans, LA
- Website
- www.oraclelights.com
- Bronco
- Base
The new Ford Bronco is simply awesome, blending the classic good looks of the original with a modern drivetrain. Our new Oracle Lighting 2021+ Ford Bronco Oculus Bi-LED Projector Headlights are significant upgrades over the factory units. Here are five reasons why you should upgrade your stockers to our latest lighting release for the new Ford Bronco.
White Part #: 5886-001
Amber Part #: 5886-005
Amber/White Switchback Part #: 5886-023
- The Upgrade is Simple
- The Bronco’s grille pops off easily for quick access to the factory lights. Here is the installation video.
- Better Visibility
- The Oculus Bi-LED Project Headlamps are ideal replacements for either the Standard or Signature Bronco lighting packages. And they are suitable for all-weather use with a 5500K color temperature that isn’t excessively harsh, causing eye strain.
- Better Looks
- Our Oculus Bi-LED headlights for the 2021-and-newer Ford Bronco combine high performance with stellar looks. The halo ring is available in white, amber or an amber/white switchback if you want a bit of both. Check out the video here to see how good they look on our Oracle Lighting Bronco.
- Built to Last
- All our Oculus Bi-LED headlights are built to last and survive use on the street or trail. Designed and developed by our engineering team in the USA, they feature rugged construction. A two-year warranty backs them, and they are DOT SAE certified, unlike some low-quality options on the market.
- Improved Safety
- The Oracle Oculus Bi-LED Projector Headlights for 2021+ Ford Broncos have a very sharp and well-defined cut-off line. They also feature a wide range of aim adjustments, making them suitable for lifted Broncos.
