If the Squatch is going to give you 4.7 from 4.46, wouldn't that make the speedometer readings become incorrect. I am guessing they are going to correct the speedometer too if you choose the Squatch package?
And what happened to the roll bar soeakersPreproduction. I should have just said unknown. Making me second guess myself since I wasn't able to take pictures of that specific interior. I'll reach out for clarification.
Yes final drive ratios and tire circumference are calibrate-able parameters within the PCM/BCM.If the Squatch is going to give you 4.7 from 4.46, wouldn't that make the speedometer readings become incorrect. I am guessing they are going to correct the speedometer too if you choose the Squatch package?
This is something that I hope we get clarification on soon. I like the idea of the 2 door modular top IF the rear windows are removable. I’m not sure about it, if they are not.I would bet the side glass doesn't come out on the 2 door . That’s a big piece of glass.
You could store them or lay flat in the back
The first thing I thought were taller bump-stops. I will have to some re-engineering.Most likely just taller bump stops to limit upward travel.
Wish they were a little more forthcoming with details though as that is somewhat important for someone deciding between the two models.
They are there. You can see them in a photo.And what happened to the roll bar soeakers
I'm starting to think the same. You can see the removable glass on the 4 door has about 2 inches of black plastic for the button release. I don't see that piece on the 2 door with the gloss painted hard top.I would bet the side glass doesn't come out on the 2 door . That’s a big piece of glass.
I am with you and wheelers know 44s are only good to 35s; high pinion 60s will work up to 40ish.I would be more concerned about the stock axles holding up to a 37" tire . If you get a look at the rear axle on that orange 2 door running 37's you can see it's been trussed & does not look like a 44 to me.
Have to wonder if the stock axles are up to the task of 37's let alone 38's reliably on the trail.
Ive only heard about it on here after the photo with the 3 ford ppl were standing around the Cyber 2-door.Agreed, but has the 2" lift been confirmed or is it mere speculation? I have not seen anything concrete on this. Do you have a link?
Thats awesome! Thank you for your service!Been there and done that. When the 2006 Dodge Ram was coming out I had my wife go sit in and check out the F-150, Chevy, and outgoing Ram. She said the F-150 and Ram felt good and had enough space.
So, while forward deployed to Iraq I bought the Ram straight from the factory (awesome discount for my situation) and it delivered in late 2005 as one of the initial deliveries when I got home.
The first time I saw it was when I picked it up and drove off the lot. I’m still driving my Ram today.
Research, research, research and a leap of faith is the only way to do it, if you can’t see or drive it. It’s a tough call to make, and I recommend that you’re honest with yourself, your risk tolerance, and the willingness and financial freedom to get out of the deal if it isn’t right for you.
Thanks and you are most welcome. I loved it, even though it sucked sometimes.Thats awesome! Thank you for your service!
Yeah it would be tricky. Would be cool if they could at least vent open on one endI would bet the side glass doesn't come out on the 2 door . That’s a big piece of glass.
Because I may not like it $50,000 worth?How bad could a test drive go that you would refuse to purchase after a 15 minute test drive waiting so long and with so many cool features about it? We know the power will be fine and handling will be good with the IFS, you going to refuse it because it oversteers on the highway on-ramp? I bought my last BMW sight unseen from the other side of the country, it was a used car, now thats risky.
