Out of Upfitter Switches, looking for a clean solution for more switches
akturbo
Seattle Eastside
'21 Bronco, 3500HD Chevy, Rav4Prime, Turbo Skidoo
The title says it all, I ran out of Aux switches and want to see what others have done. I need at least 4 more switches. What have you all done for switches?
This is interesting, but not exactly feeling it, I like stuff that isn't noticable/looks stock.
Ford Bronco Out of Upfitter Switches, looking for a clean solution for more switches 1683304725143
akturbo
akturbo
Seattle Eastside
Upfitters - Done
Aux 1 - Rough Country 20" Light Bar, secondary switch to toggle DRL or full brightness
Aux 2 - A-Pillar Baja Designs Squadron Pro Rs
Aux 3 - 500Amp Winch Relay/ARB compressor relay (double tapped)
Aux 4 - Interior LED Lighting
Aux 5 Always On - Midland 275
Aux 6 Always On - Dash Cam
New Switches needed
1 - ARB Compressor Relay
2 - 20" Light bar DRL/Full-on Switch
3 - Rear lights
4 - Rock lights
Rear Switches - Done
1. Cig lighter socket - Fridge relay (upgraded power)
2. Rear LED Lighting
3. USB-C/A outlet with Voltage reading
Nick@Apollo-Optics
Nick
Houston
www.apollo-optics.com
2022 Wildtrak | 2021 GT500 | 2019 F-250
I've always been a big fan of Switch Pros products and they offer a nice clean mount for the Broncos as well.
Switch Pros SP-9100: SP9100 Switch Panel Power System SP9100
Bronco Mount: 2021+ Bronco Mounting Kit for SP9100 & RCR-FORCE 12 SP-BRONCO
Ford Bronco Out of Upfitter Switches, looking for a clean solution for more switches 1683306227574
If you wanted something that was very OEM looking. You could replace the OEM upfitters with the Switch-Pros RCR Force 12 and then use the the SDHQ mount overhead and put it in the factory location, would look like this:
Ford Bronco Out of Upfitter Switches, looking for a clean solution for more switches 1683306382110
RCR-Force 12: RCR-FORCE 12 Switch Panel Power System RCRTOUCH12
Toccoa
Isuzu Rodeo Sport
Ford Bronco Out of Upfitter Switches, looking for a clean solution for more switches 1683306746163
Some inspiration. ;)
akturbo
akturbo
Seattle Eastside
LSU Jonno
Huntsville, AL
2022 Bronco
What’s the purpose of using aux switches for a com or compressor?
the com unit already has a power switch and you can install it to bring fused power to it from battery, acc switch or full ignition. Seems unnecessary to also put the aux switch in the mix. Same for ARB compressor and dash cam.
akturbo
akturbo
Seattle Eastside
I don't want it setup that way, I know how vehicle wiring works.
akturbo
akturbo
Seattle Eastside
Thanks! That's cool, I haven't seen this switch before! I'll look into it more.
Nick@Apollo-Optics
Nick
Houston
Sounds good! We have a link to the RCR Force 12 on our site and we also carry the SDHQ mount for inside and under the hood. Plus, we carry an extended communication cable to give you enough length to wire it up at the roof line. If you have any questions or would like more info, please don't hesitate to send me a message.
Grumpy
Who's
On a Lake
22 2dr
I installed Auxbeam 8 gate switch.i put the control panel up on front of the sunglass holder. Have not had any problems what sk ever. Neat and clean with all wires concealed.
Ford Bronco Out of Upfitter Switches, looking for a clean solution for more switches IMG_20230205_152950
Pugsly
Clayton, DE
2014 Ford Fusion
akturbo
akturbo
Seattle Eastside
I highly recomend the Trigger 6 shooter. You can use your phone for switches, use their wireless switches or even use your own with the aux port.
Trigger Wireless Accessory Controller Six Shooter , NEW ITEMS EB: WILD HORSES 4X4 Bronco Parts
Ok, that is trick!! Watched some videos on it, I'd add more lights just to use all of those features! I can see adding the 6 shooter and changing up my whole wiring scheme. This is my type of device, my search might be over, thanks!!
Pugsly
Clayton, DE
2014 Ford Fusion
I love mine
Ford Bronco Out of Upfitter Switches, looking for a clean solution for more switches IMG_3041
Ford Bronco Out of Upfitter Switches, looking for a clean solution for more switches IMG_2850
nametaken
Illinois, Beecher
23 Bronco 2dr, 22 Model 3, 23 Frontier, Vanderhall
good idea
