crackedbackdoor
Georgia
www.instagram.com
2021 Ford Bronco OB & WT
Was looking at the very same tire today. Would like feedback on road noise. Looks nice
Road noise is minimal at best. If you want an aggressive looking tire that you can take on 5+ hour road trips, this is the tire for you. However, check out the Toyo ATIII, and Nitto Recon Grappler.
grayshadow
Charles
Humble, Texas
Son and I was discussing Toyo’s yesterday. Any feedback on Toyo M/T?
crackedbackdoor
Georgia
www.instagram.com
The Toyo M/T is pretty much all I run on my super duties and I will be putting a set of 37x12.50R17 on a Bronco when my 4WP coilovers come in. They have a little bit of road noise but it’s something I’m used to. Wouldn’t say it’s obnoxious by any means. They pull great through mud and have taken some pretty good rock abuse without major chunks getting cut or taken out. Never have had a defective tire or set. I highly recommend them!
newsman9
Houston
I just installed the 4 Wheel Parts level lift kit (62210k) on a Carbonized Gray Outer Banks with 295/70R18 (34.2x11.7) Nitto Ridge Grapplers using the stock wheels. I knew the fitment would be tight but it worked out well with zero rubbing.
This is kind of exactly what I'd hope to do, right down to the trim level (OBX). So glad it works!
My question: Does this sort of modification do anything to the warranty or extended warranty? I mean, the truck literally says "lift me baby" on the wheel well so it shouldn't, right?
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
I just installed the 4 Wheel Parts level lift kit (62210k) on a Carbonized Gray Outer Banks with 295/70R18 (34.2x11.7) Nitto Ridge Grapplers using the stock wheels. I knew the fitment would be tight but it worked out well with zero rubbing. I’ve also tinted the front windshield and 2 front windows. Here are a couple of photos:
That looks badass
BTomorama
Atlanta, GA
2015 Nissan Rogue
What gearing do you have? Stock 3.73 or the upgraded 4.27?
noliveaxle
john
Riverside, Calif
2015 jku rubicon
this is going to be the nicest OB we see in my opinion. completely stock looking, which i like with perfect fit and tire size. i like the tint too, but normally dont tint vehicles i use for off roading in the night.
crackedbackdoor
Georgia
www.instagram.com
Thanks buddy, I appreciate the kind words. I have a Wildtrack on order so this is just for fun.
crackedbackdoor
Georgia
www.instagram.com
This spec is just the base 3.73. I wouldn’t necessarily consider it to be sluggish but it doesn’t pulled like my tuned 6.7 that’s for sure. I think with the upgraded gearing and the 2.7L it will feel just fine. Not looking for speed as much as I am a suspension performance.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Gotta be honest. I had no idea is was legal to tint a windshield. I am about to do the front windows this Saturday...
Millchil
Nicholas
Austin, Texas
2021 Bronco; 2019 Infiniti QX 80
Nice! Getting almost the exact same work done to my gray one in two days. Just a slightly different lift kit, but same tires.
rmc523
South Florida
2009 Ford Flex; 2018 Mustang GT
So what is your tint vlt? I am looking to get 50% on the windshield and 20% the rest.
I have 70% ceramic on the windshield and 20% ceramic on the rest on my Mustang - it makes a big difference with the heat.
