Outer Banks grill similar to Bronco R mini light bars.
U13Roadster
Ryan
Charleston SC
1966 Ford Bronco
My folks reserved an Outer Banks edition. I was considering the six slots in the grill and then it hit me. The Bronco R has 6 small light bars. This will likely be an optional add on for the Outer Banks style grill I’m guessing.
Ford Bronco Outer Banks grill similar to Bronco R mini light bars. 7226F20D-D7A9-458E-AC71-C8444BE3BB37
LonestarBronco
2006 F150
This was specifically mentioned in a video with the chief designer for the Bronco. The 6 light bars were a nod to the 6 hole grill.
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
Probably not the best idea to take the 6 holes designed for cooling flow and obstruct them with light bars.....
Rocketman
Georgia
2018 F150 FX4, 1994 F150
According to the Ford.com/Bronco website, that grill belongs to the Big Bend trim package.
vintage
Summerfield, N.C.
Wrangler JLU Rubicon, 4Runner Trd Pro, Indian Chieftain, Indian Springfield
I did the amber lights in my Trd Pro. Thinking of doing the same to my Bronco.
Ford Bronco Outer Banks grill similar to Bronco R mini light bars. 3pcs-4Runner-Raptor-Lights-Amber-_-Amber
martyb
Marty
Winneconne, WI
GMC Sierra Denali, VW Atlas
OB still has the 6 holes, just different lights...
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
So I purchased the OB grill in hopes to do this but now that I have it in hand I am rethinking it. If I only did the bottom 3 do you think there will be a cooling issue?
Hyfly
Idaho
BRONCO
Ford Bronco Outer Banks grill similar to Bronco R mini light bars. 78174222-72BE-42E1-8740-47818F13E6EF
I am doing Amber backlit on the 'BRONCO' letters to give this effect as well as light up the 'BRONCO' letters
@BadBlueBronco
Kc
Los angeles
hopefully some one makes a little light pod that works with badlands grill like this.
AZ_BRONC
Tempe, AZ
‘17 4Runner, ‘16 BMW 328i, ‘96 Stang GT, ‘19 Mini
Blocking the air here would be a good way to wreck your turbos.
@BadBlueBronco
Kc
Los angeles
holo37
Bucks Co PA
Jeep Grand Cherokee Limited
@BadBlueBronco
Kc
Los angeles
So after removing the grille there is a large plastic plate that blocks the top half of the grill. Behind that the intercooler is also blocked. I assume this is to keep people out from under your hood. Since all but 1 duct is blocked currently with my badlands camera mount with a OB grill. I should be ok to put lights in the top 3 and let the bottom 3 scoop air like normal?
