Outer Banks tires - what larger size upgrade possible without lift?
gothavit
jake
florida
jeep cherokee
OK so looking at the outer banks next to the wildtrak the tires look so small so what sizes tires do you think would fit safely with out lifting or changing rims
Advertisement
tx96
Seth
VW CC
I've also thought this. What's weird is I don't think it's the tires necessarily as much as it is the rims that give them the illusion that they're smaller. The tire size is the same on base, BB, BD but look smallest on OBX lol
Tdifonzo
Thomas
Audi S3
Vehicle Showcase
It’s not the diameter. It’s the width and aggressiveness that make them look pitiful.
gothavit
jake
florida
jeep cherokee
  • Thread starter
  • Thread Starter
  • #6
so do you think a little wider tire would fit
Tdifonzo
Thomas
Audi S3
Vehicle Showcase
I have to imagine a 33" tire similar to what comes on the Badlands will fit. The only problem is how much will that slow the OBX down with its gear ratio. 🤔
Headsong
08 Tundra
Yeah, I don't understand why folks worry about the fit. The frames are all the same! It's gear ratio that may need adjustment.
Lindy08
Cliff
Illinois
2009 F-150
OBX comes with 32" tires, would it really need to be re-geared for 33"s?
I realize stock tires are a different profile tire than if you went with say, 33" KO2s.
Jr87mustang
Josh
Northern Cali
If I stick with OBX the 4.27 or whatever you can option in for will be fine.
Tdifonzo
Thomas
Audi S3
Vehicle Showcase
and what would that gearing (4.27 or whatever) do to the stock tires?
Cruising on the highway at 75 MPH:
32" tires
3.73 gears = 1926 rpm
4.27 gears = 2205 rpm
33" tires
3.73 gears = 1868 rpm
4.27 gears = 2138 rpm
Lindy08
Cliff
Illinois
2009 F-150
32" tires
33" tires
Thank you, pardon my ignorance.
Gamecock
2011 FJ Cruiser
It's the amount of lift that provides extra clearance....the Badlands is lifted to fit 33s. It is an open question as to whether stock non-badlands suspension would allow for 33s to not rub.
Tdifonzo
Thomas
Audi S3
Vehicle Showcase
A 1/2" increase all around the tire will most definitely fit. The tire width is a whole other thing that we need more info for. I don't want to look good but not be able to turn. Lol
Advertisement
Advertisement
