Overhead garage hardtop hoist for storage
BlueBronco
DFW
Signed, and engineer who has designed several different load bearing hoists.
Aren't all hoists, by definition, load bearing?
Signed, construction guy who will never waste an opportunity to poke at an engineer :p
Bronco4lyfe85
William
2019 Challenger Scat Pack
I like this Harken Hoister shown on this Jeep. Hope it's just as easy on the Bronco.
This is actually kind of cool and my garage is stupid high so it could work very well.
North7
North Texas
SUV
Poke away, the answer is no. The hoist is rated to lift a certain number of pounds, some may call it "load rated" but that just means the hoist can lift that much weight...
IF, IT IS ATTACHED TO A LOAD RATED STRUCTURE that is designed for the that weight.
Hang a 500, 1,000, 2,000 pound Harbor Freight Hoist from the attic joists in the standard garage at your house to lift the engine out of your car, power up, and watch the ceiling joists and roof collapse onto your car.
Hang the same hoist from a steel girder in a commercial building, that is Load Rated for your choosen Hoist Lifting Capabilty, and you will now have no problems pulling the engine.
pan-y-cerveza
Manitoba
Tacoma Pro
Ha. Engineers. So serious.
Both the hoist and the steel (or whatever) must be load rated.
Signed: Ironworker and rigger.
Blksn955.o
Greg
Wentzville, MO
17 Ford Escape Ti, 94 Ford Mustang GT, 21 BL
I do like the pully setup and for under 200 that might be what I do instead.
North7, when we actually get our broncos I think a great thread from an engineer standpoint is what to reinforce to hold the weight.
I am holding off running some POE cable for a ubiquiti outdoor camera to maximize my attic time.
M&M Beer
Marty
Ford Edge-F-150 Supercrew
CARdiac
Joel
Maryland
Hummer H3 Alpha, MINI Cooper S JCW, TVR 280i
WadeWolf76
Damon
Kansas
15 Wrangler JK Willy's, 67 Ford Mustang coupe
I have one of these, works on my 2 door and the wife 4 door Jeep hard tops. I would assume given the dimensions for the Bronco it should work for that as well.
fraserjr
Fairfax, VA
2021 Ford Bronco Badlands 4 Door
Reviving this thread to see if there have been any solutions for the middle roof section and the back section of the MIC top. My wife is barely tall enough to help me lift either section over the top of the Bronco so a 2 part lift solution that I can operate myself looks like the best scenario.
