- Banned
- #121
Badlands and sasquatch suspension are one and the same with the exception of less travel in Sasquatch, assumed to be accomplished by bumpstop, due to 35s.Would like more info on the "high clearance suspension" option as well and what that does over the Badlands original suspension.
Basically Sasquatch package on a Badlands consists of wheels, tires, and bumpstops.
FWIW I find steam to be a better option for debadging than a hair dryer or heat gun. With a heat gun especially it's real easy to damage the paint, some are quite powerful.Vagelands badge. Just use a heat gun or a hair drying to warm it up and it'll peel right off. Use a little goo gone to clean up any residue and put a small amount of wax in the area and you're done
You can get a wallpaper removal tool (steam gun)at any big box home store and they work great!
You need to perfect your resting bitch face.Yeah, my introverted self would not be able to deal with those constant convos at the pump. I barely get by on my motorcycle gas station conversations ?
Looks like it has the Sasquatch package. those are bead lock wheels and the new 35 inch good year tires.
Those are the new 35" good year tires on the bead lock capable wheels
Those are the 35" good year tires. Tread pattern and and good year on the side wall give it away
FYI if you hit the "+quote" button next to "reply" on multiple posts and then the "insert quotes" button next to "post reply" you can reply to multiple posts with one reply.Those are 35 inch good year tires
