Paint removed under mic top?
Techun
Pa
BD, 2.7, MIC, 4dr
For those who have removed their rear top, are there multiple areas of exposed metal with the paint has rubbed away? I removed mine for the first time and there's bare metal at the top bolts and the rear corners.
j_marinelli
Spring Branch, TX.
Mine had some spots down to bare metal. I ended up getting these to help protect:
Ford Bronco Paint removed under mic top? 71G77y7LE-L._AC_SL1500_
Full disclaimer though, the paint comes off the bolts on the body panels when you take them off and reattach to secure these on.
Juventus
CT
Chevy
Where did you get these?
j_marinelli
Spring Branch, TX.
indio22
Chicagoland, USA
Nice. On my TJ, passengers are often climbing up the rear tires and stepping on the body side to get into the rear seat. These covers would provide some protection from shoes. But dang, seems like only available for 4-door Broncos?
555-RGNE
Pop. 196, Texas
2022 Basequatch 2dr 2.7L
I have a 2022 2 door w/ 27K miles and haven't seen any wear or bad spots on the paint under the top. I always wash my Bronco prior to taking the top off and wind up wiping down the painted area underneath once it's off to remove the dust/dirt and the paint is as good as everywhere else.
JonDW29
Jon
NoVA
'16 F-150
I've got some wear around the bolt holes on the roll bar where the front two top bolts with the floating arms connect.
