Painting MIC top - will material hold fillers and paint?
Markkelly1965
Iowa
66 Bronco, 09 Expedition, 77 Vette
Does anyone know if the composite material of this top would
hold any types of fillers and paint?
beachman101
;pkl
I believe its thermoplastic. Might be the same stuff that jeep uses so if they are able to paint it , so would you.
however unless you are going for a body match , i would just go with linex type stuff and make the top indestructable
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Not sure on the exact thermoplastic makeup. Quite a lot of discussion on painting it though.
Everyone agrees that the correct answer is a range between ā€œthatā€™ll never workā€ to ā€œIve got a guy who does it all the time and it looks great.ā€
Seems the biggest concern is the MIC top has a very fine texture to it, and thereā€™s no consensus on what you need to do about it to get good adhesion.
Ford Bronco Painting MIC top - will material hold fillers and paint? 1612014577072
BuckinT29
Travis
Los Angeles
Alfa 4C Spyder, Ducati V2, BMW X1
Iā€™m sure you can xline the top. Will be a bumpier finish but will outlast the next apocalypse.
BuckinT29
Travis
Los Angeles
Hence the scratch proof feature that the mod top doesnā€™t have.
Markkelly1965
Markkelly1965
Iowa
Will it accept dye? Would really prefer the top to be black
Headsong
This is the search button, I made it bigger and just as clickable as ever.
Ford Bronco Painting MIC top - will material hold fillers and paint? 1612020967298
Yep. There's a guy here who runs a shop and has given detailed instructions.
JDC351
Jared
465 Tanners Bridge Rd. Monroe, GA 30656
1976 Bronco, 1996 Bronco, 2012 F150
You can paint most any type of plastic these days. Itā€™s all about prep. Being a fine texture means scuffing things down. A lot of plastics require a flex agent, but any skilled painter can make it work... just don't hit up Maaco and expect it to last.
Karl_in_Chicago
Karl
Chicago
Maaco?!? Go for the value, stay for the quality, Earl Scheib! :ROFLMAO:
Ford Bronco Painting MIC top - will material hold fillers and paint? Earl_Scheib
Prkelly
Pat
Washougal
