Appalachia_Ewok
J
Tennessee
'02 PT Cruiser, '62 DeVille, '96 XJ, '23 Bronco
I wanted to see what the 4 door Bronco would look like with just some of the doors/roof panels removed so I went ahead and (crudely) mocked up various roof panel/doors removals with the B&P and MS Paint to give a better idea of what it will look like.
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 2021 Bronco hardtop panel removed 1
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 2021 Bronco hardtop panel removed 2
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 2021 Bronco hardtop panel removed 3
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 2021 Bronco hardtop panel removed 4
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 2021 Bronco hardtop panel removed 5
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 2021 Bronco hardtop panel removed 6
Additional ones by @Username_not_found. 4 door with roof rails on and the front roof panels off.
Appalachia_Ewok
Appalachia_Ewok
J
Tennessee
Maybe I don't need the bimini top... interesting.
I'm not totally sure leaving just the front panels is an option, but I really hope it is. If anything just the front latches will probably hold it fine at slow on trail speeds.
Or maybe just some C clamps at the rear...
pan-y-cerveza
Manitoba
Tacoma Pro
Nice work.
You inspired me to do a very lazy attempt at doing the two I haven't seen but wanted to see. 4 door with roof rails on and the front roof panels off.
This is how I'm planning on running mine most of the summer.
Hopefully someone comes up with some sort of quick top that can easily be taken on and off with the rack on.
Appalachia_Ewok
Appalachia_Ewok
J
Tennessee
Sounds like what you plan on doing with your $40,000+ truck may be different than what I plan on doing with mine. Any time I'm going to be at extreme angles or large rocks (which will be a rarity anyway) I'm gonna go slow, and any time I'm on a smooth(er) forest road or something it's still gonna stay under 25mph. I don't plan on doing the Baja 500 haha. I wouldn't trust it at speed because of the wind catching it and bending stuff. Jostling around a little should be OK.
  • Like
Reactions: RLW
Appalachia_Ewok
Appalachia_Ewok
J
Tennessee
Vortexes are crazy man. I'm not a physics guy or anything but in a pickup truck the aerodynamics roll the wind and blow it back forward. Which is why if you open the rear window on a pickup and have leaves/trash in the bed it all blows into the cab. By leaving the front panels on the Bronco and removing the rear ones you're creating a similar situation to a pickup bed. With only clamps on the front it's asking for trouble IMO. But hey, if it doesn't cause a problem, great, I'm just cautious.
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 1607014650461
Rick Astley
Up Doug's ass
d
Some random food for thought when it comes to the now-daily arguments about the Bronco being a $40K rig, your 2002 PT Cruiser adjusts to essentially $30,000 in today's dollars (I have assumed you have limited trim, since the base bronco is $12K under your stated price argument)
The Bronco won't be too far off the adjusted price of your PT. Do you feel your PT was too luxurious and opulent to drive it as designed? (Serious question, I have friends with HHR's but not PT's. To a man they say the HHR is a roached-out POS vehicle).
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 1607016332260
Ford Bronco Partial Roof Panels / Doors Removed Bronco Mock-Ups. 1607016353294
