- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
The Dark Grey Line has been discontinued, we have the final batch of these in stock and ready to ship, discounted pricing is live on the website!
Pelican Dark Grey BX80 Cargo Case BX80-DKGRY
Highlights:
Keeping your gear safe is critical when you head off into the great outdoors, and Pelican's BX80 Cargo case can keep even the most sensitive hardware secure when you are off-road. The BX80 is designed to hold life?s adventures and is the perfect solution to store gear, tools, camping accessories, clothing, and even dry food. Pelican Cargo cases feature a lifetime guarantee and can be attached to your truck bed, roof rack, or stored in your SUV. The roto-molded durable design provides customizable mounting configuration so your cargo is easily accessible. Pelican's Cargo case heights are compatible with truck bed covers.
Roto-Molded Plastic Construction and Dark Grey Finish
Pelican Cargo cases are lockable, weather-resistant, and e-coated plates designed to withstand corrosion. The easy install mounting brackets (sold separately) allow you to remove the cargo cases from your vehicle with just the pull of a pin in less than a minute. The heavy-duty lay-flat handles stay out of the way and offer a comfortable grip when engaged. The Polyethylene roto-molded cases are designed to withstand impact, extreme conditions, and the lightweight polymer ads UV protection to the pelican cases. The tie-down pates are compatible with Pelican's vehicle mounting kits and also can be used with ratchet straps or rope. The rubber gasketed lid has been tested to Mil-Spec 810G to protect against 70 mph wind-blown rain and dust, and have been city crash tested.
Size Specifications
Highlights:
- Weather resistant including rubber gasketed dustproof lid
- E-coated steel prevents corrosion
- Roto-molded construction withstands severe impact
- Prevent theft using any standard padlock
- Mountable accessories give you full access to your cargo
- Lightweight polyethylene offers UV protection
- Crash tested and can withstand nature's harsh elements
Size Specifications
- Interior L: 20.75 x W: 12.25 x D: 13.25
- Exterior L: 25.00 x W: 17.25 x D: 16.00
- Interior Volume: 1.95 cu. ft.
- Weight 19.3 lbs
- Minimum Temperature: -20° F
- Maximum Temperature: 140° F
