A few things to be warry of with a spring seat spacer kit for those with Bilstein dampers:
1 - With the stock Bilstein dampers, there is ~1.9" of FA damper travel and and ~3" of rear damper travel from curb height before ESCV engagement in the rebound direction. On the front damper, you will be in ESCV 100% of the time with this lift. Rebound ESCV damping is ~5x the damping in the normal ride zone...this will create some interesting body control situations.
2 - The longevity of the shock will be at risk because of this constant ESCV engagement. The damper is not tested for 100% ESCV engagement, the design intent is 10% (if I remember correctly).
3 - The stock spring is traveling 2" more than designed. It may be going into bind at full travel...at a minimum, it would be harder to achieve full articulation due to the increased spring rate at full compression.
As one of the guys responsible for the birth of the ESCV tech, I would never recommend a spring seat lift for these dampers.
