Perch Collar or Hybrid Spacer Lift for Sasquatch?
Perch or Zone 2/1 hybrid lift
  • Total voters
  • Poll closed .
Badassbronco
Georgia
I’ve read through a bunch of posts and still can’t decide. I’m not a hardcore off reader but been hitting trails maybe about once month. I’m wanting a little more lift to the Sasquatch Bronco. One day a may even try to fit 37s but sticking with 35s for now.
I’m leaning toward a perch collar since I believe it won’t be as bad for cv binding.
I figured I will do poll to see why you guys think.
Bradley Thornton
Bradley
Hattiesburg MS
Bradley Thornton
Bradley
Hattiesburg MS
Badassbronco
Georgia
I ordered the perch. Supposedly Zone stated that 2022 will sag in the back a little and are still working on a fix. Maybe due to the new sway bar.
JRock17
Justin
Jersey
Ice Mountain 4dr Wildtrak
Where did you order from? I was looking at SVC and RPG…..RPG told me I can run the 2.25 front and back to keep factory rake which I like….
Badassbronco
Georgia
I went with the RPG just because Zone doesn’t recommend their lift for 2022s at this time.
Mine should be installed by the weekend.
RubyRedGT
Greg
Pittsboro, NC
21 Bronco. Sold the 1968 and 2015 mustang GTs
Thoughts on the Zone 2” (PN F1221 for Bilstein shock vehicles) but installing front spacer only … i.e., without installing the small front spring perch collar? Reason I ask is if I’m lifting the rear only 1” then I only want 1.25” or 1.5” in front and not 2”.
Felix808
SRV CA
I vote Perch collar 2" all around (SVC)
I may still add 1/2 of the 1" level to the rear if needed once truck is loaded down.
VelocityBronco
E
Bronco Badlands, F-150 FX4, Explorer Platinum
That is how the SVC collars work, same size for all for shocks so it keeps a little rake after its lifted.
I have the SVC collars.
Felix808
SRV CA
TLO
E
Canada
youtube.com
2 door Squatched
Noticed Bronc Buster has an assortment of 2 and 4 piece perch collars available.
I'm thinking just the front 1" pair to compensate for the winch/winch mount thats about to go on...
Or dammit, maybe 1.5" front and 1" rear 🤷
I know when I'm all loaded up for travel, I sat pretty level, albeit pretty squished prior without the winch setup...
4 corners adds quite a lot more work and $$ to the job though
