Fordboi
Cameron
Murica
1966 Ford Ranchero
For giggles I just measured my Raptor from the edge of the tread to the edge of the tread. It's 83". I see a couple of possibilities. #1 the Warthog will have more suspension travel than the Raptor due to longer control arms and rear coils. #2 this is just a mule with a mix of test parts. What has be baffled is the Ranger frame is about 12" narrower than the Raptor. That means that the control arms and wheel offset need to make up about 6" per side. It will be interesting to follow the progress.
i'm pretty sure the next gen ranger is being based off of the bronco, not the other way around, so you can't exactly base new bronco off of old ranger...
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
The frame rail width will be very close to the current Ranger.
ROCKO
San dimas
Whats the point of the Raptor, we already have the F-150, same as the Warthog, Ford Corporate Profit$$$$$$$$
Well the raptor is a Baja cable truck your standard F-150 isn’t.
Parker
PA / CA /AZ
Gr Che Overland, Corvette, Tahoe, 46 Chevy 2ton
This is my Jeep TJ with 1-1/4" spacers, JL rubicon rims and 285 tires in the Bronco Warthog tracks (from my Warthog sighting pics - link below).
Here's some stats calculated by @Apples:
  • A stock TJ is 68.3" wide + 2.5" in spacers = 70.8" width
  • It looks like the TJs passenger tire is sitting on the inside edge of the Warthogs tire track. So we add the width of a 315/70/r17 tire (12.5") and you have an overall width of 83.3" for the Bronco Warthog.
  • For perspective, compare that to the Wildtrak's width of 76.3"
More pics / video: Bronco Warthog and Badlands Spotted Testing GOAT Modes and Trail Turn Assist (Pics + Videos)
Bronco Warthog compared to Badlands:
Most trailers are 84 inches - Raptors need not apply.
MaverickMan
Shane
Dont know if anyone has posted this yet but I measured my 96 Bronco which is a wide truck at 77.5" with 31x10.50 tires. So on equivilent tires it would be only 79.5". However I will state that my now defunct Quadravan E250 is about 81" to 82" thats a F350 dana 44 with 33x12.50s.
Verdict is that the warthog is wide and better atleast have the godzilla motor in it. If not then something bigger!
Boxer4
TRUCK
WT track width is 66.9 + 12.4 tire ( 315 /70/R17 ) = 79.3 overall tire edge to edge not 76.3 @Apples
Apples
Nick
2022 Jeep JLUR, 2004 Lexus GX470
CinciGP
Monroe OH
`72 Jeep CJ6, `04 Jeep Rubicon, '18 Jeep JLU sport, `09 Mercedes CLK550
I just measured my rubi. Track is 60 inches. This is outside tread to inside tread. My tire width is about 11 inches. So the WH track is around 71 inches? Per Ford the wild track is 66.9 inches. So the WH is like 4 inches wider?
Ragtop1962
Springdale Ar
2001 Toyota Sequoia
Did you make plaster casts of the tracks?!?
CinciGP
Monroe OH
Sorry. Left my csi kit at home.
lsustang05
Houston
2013 Ford Raptor SuperCab
I'm far more curious what motor it gets (3.5 maybe?)
As for width...
WildTrack is 6' 3" wide
Warthog is 6' 9" wide
that is literally 3" on each side...barely noticeable unless side by side IMHO basically the width of an iPhone.
Build your look, Bushwacker Fender Flares run from 2-3.5" widths on each side, then toss on backspacers and a 35x13.5 tire, same look :)
3” on each side is hugely noticeable. You have to not be paying attention to miss it. For reference - same wheels and fenders in these pics:
Stock width raptor (aftermarket wheels):
Ford Bronco Perspective Pic Shows How Wide Bronco Warthog Track Width Is – Approximately 83.3″ Inches! 8D2D0F72-2B7B-4388-84B8-48D3A7032B7F
Same Raptor with +3 Mid Travel suspension from SVC:
Ford Bronco Perspective Pic Shows How Wide Bronco Warthog Track Width Is – Approximately 83.3″ Inches! 8758A953-43CD-4FAB-9D70-2813E1C0100A
Ford Bronco Perspective Pic Shows How Wide Bronco Warthog Track Width Is – Approximately 83.3″ Inches! 35E95FBE-A8BD-44EC-A68A-47D5A0B49696
lowmpg
Ryan
Maryland
F350
3” on each side is hugely noticeable. You have to no be paying attention to miss it. For reference - same wheels and fenders in these pics:
That looks silly. Sorry but limit mods will make it 'look' just as wides a "Warthog" math is math ;)
lsustang05
Houston
I don’t disagree - it needs wider fenders to look better.
I never said you couldn’t get the same look. You said it wouldn’t be hugely noticeable. That is objectively false based on the pics above.
Edit: it’s also not just the looks. The warthog will be wider due to increased travel. So while the look is attainable with wheel spacers, the performance will not be the same or even close.
