Toccoa
Isuzu Rodeo Sport
Bronco ain’t small. ?
JT1
James
OK
2017 JK Willys
Someone did math wrong on the TJ to JL wheel conversion. A Stock TJ Dana 30 front is 60.5" wheel mount to wheel mount. You added 2.5 inches of spacer, but JL wheels are 6.2" backspace. So, my math says 60.5 plus 2.5 (spacers) plus 2.6 (1.3 out to 6.2 inches in on a 7.5" wheel x 2) get to 65.6 outside edge to outside edge of the wheel. The tire width get you another 3.7 inches wider for a total of 69.3 inches, outside to outside. The 12.5 inch tire gets you to 81.8. Thats 5" wider than a wildtrack, 2.5" per side. Raptor is about 6" wider than an F-150, so within the realm of normal Ford SOP
stonerdoom
chicago
2004 Ford Explorer Sport Trac
Look, I'm dumb... does the warthog have a different frame and/or axle that is giving it a different stance?
lowmpg
Ryan
Maryland
F350
I'm far more curious what motor it gets (3.5 maybe?)
As for width...
WildTrack is 6' 3" wide
Warthog is 6' 9" wide
that is literally 3" on each side...barely noticeable unless side by side IMHO basically the width of an iPhone.
Build your look, Bushwacker Fender Flares run from 2-3.5" widths on each side, then toss on backspacers and a 35x13.5 tire, same look :)
BroncoJay
Jason
Iowa
Tacoma
That’s pretty impressive...that pig is a wide bi$ch
BuckinT29
Travis
Los Angeles
Alfa 4C Spyder, Ducati V2, BMW X1
Thicccccc
Incognito
Phoenix
2017 jk
That thing is as wide, well built and sexy as Suzy Cortez.
TTown
Jon
Tulsa
2006 Explorer; 2019 Honda CR-V; 2020 4Runner
I personally think it starts to look kinda stupid when 90% of the tires sit outside the body of the vehicle (like what you see on some jacked up redneck pickups). Maybe the Warthog will be a pleasant surprise.
North7
North Texas
SUV
Redneck Bronco with swimming pool fender flares the Warthog is not.
Fordboi
Cameron
Murica
1966 Ford Ranchero
she thicc boi
Salt Lake City
2011 LT Taco
I'm guessing that warthog has some sort of factory long travel kit on it. My 2011 tacoma has a +3.5 long travel kit (total chaos) on it and the overall front track width is right at 84" with my wheel offset and tire size (255/85/16) (tall 33's) with a 4.5" backspacing.
The +3.5 means that the front control arms are 3.5" wider (per side) over stock. Basically my truck is 7" wider over a stock tacoma. This gives me 14" of front wheel travel with 4wd (I also have extended axles to retain 4wd).
beachztt
Russ
Palmer Lake, CO
2012 Raptor- Tuxedo Black, 2017 Jeep JKU Rubicon Hard Rock- Built
Sounds about right to me. My Gen 1 Raptor is listed at 86.3. I have been speculating that the Warthog will be longer/beefier UCAs, LCAs and axles in the front with the wider rear end like its Raptor brethren.
Free Pizza
Tommy
New jersey
Jeep cherokee
Yes! Math nerds putting in gods work once again.
ROCKO
San dimas
This is my Jeep TJ with 1-1/4" spacers, JL rubicon rims and 285 tires in the Bronco Warthog tracks (from my Warthog sighting pics - link below).
Here's some stats calculated by @Apples:
  • A stock TJ is 68.3" wide + 2.5" in spacers = 70.8" width
  • It looks like the TJs passenger tire is sitting on the inside edge of the Warthogs tire track. So we add the width of a 315/70/r17 tire (12.5") and you have an overall width of 83.3" for the Bronco Warthog.
  • For perspective, compare that to the Wildtrak's width of 76.3"
More pics / video: Bronco Warthog and Badlands Spotted Testing GOAT Modes and Trail Turn Assist (Pics + Videos)
Ford Bronco Perspective Pic Shows How Wide Bronco Warthog Track Width Is – Approximately 83.3″ Inches! that-bitch-wide-and-all-outside
Bronco Warthog compared to Badlands:
What is the point of this warthog? To me the bronco is an off-road vehicle. And by that I’m talking overland/rock crawling. I don’t see it as a Baja racer. I’d like to see them build an ultimate rock crawler or overlander.
