No. These are the standard lights. The rings are not halo.
I agree though we seem to be in the minority. Something about the grille doesn’t work for me. The way it wraps around gives it a slightly tacked on look, vs the integrated feel of the early Bronco. Im still buying one, but am hoping for an aftermarket “fix”.The one thing that rubs me the wrong way still. I wish it was full fenders with the side marker out the side. And not a wrap around grill. I hope the after market has a fix.
If O.J. owned the white O.G. classic Bronco, that would would place a vibe on the new white retro Bronco..If it wasn't for OJ, that would be the color.
Looks like it has the Sasquatch package. those are bead lock wheels and the new 35 inch good year tires.Is this a Badlands without upgraded headlights? Is this an option? Wheels don’t look as small from this angle.
Those are the new 35" good year tires on the bead lock capable wheelsThe stance of this vehicle is so nice that 33s don’t even look small on a 4 door. Good to know ?
Those are the 35" good year tires. Tread pattern and and good year on the side wall give it awayI’m confused with the beadlock rims. Are we sure those are 33s and this is a non-squatch?
also, I’m guessing the bead lock capable rims are available on the BL, for $2500 and 35’s, and 4.7 gearing. With SAS lol... sorry, I just need b&p
Those are 35 inch good year tiresThose are 33s and non-Squatch. Check out this video of 2-door black Badlands. It has the exact same wheel/tire setup as this white Badlands. Looks great to me!
They are 33s with beadlock. They make both. This is not a Sasquatch package. The 33s on a badlands can come in the Goodyear MT or BFG AT. ThanksThose are the 35" good year tires. Tread pattern and and good year on the side wall give it away
To get the bead locks for the bad lands, per the info ford releases earlier unless it's changed, you have to order the the Sasquatch package.They are 33s with beadlock. They make both. This is not a Sasquatch package. The 33s on a badlands can come in the Goodyear MT or BFG AT. Thanks
oh they are I though the beadlock wheels came with 33s like the badlands at the Colorado event?Those are the new 35" good year tires on the bead lock capable wheels
Apparent beadlocks will be available on badlands without Sasquatch and with 33” Goodyear MTTo get the bead locks for the bad lands, per the info ford releases earlier unless it's changed, you have to order the the Sasquatch package.
https://www.ford.com/cmslibs/conten.../suvs/bronco/2021/pdf/21_Bronco_lineup_HR.pdf
I don’t think it’s 35’s, it’s the 33’s that are on the trail rig bronco concept.oh they are I though the beadlock wheels came with 33s like the badlands at the Colorado event?
Correct. 100% 33s - NOT 35sI don’t think it’s 35’s, it’s the 33’s that are on the trail rig bronco concept.
Correct. The Ford marketing guy said those are optional wheels with 33" tires for Badlands, when this Bronco was at the NYSE.They are 33s with beadlock. They make both. This is not a Sasquatch package. The 33s on a badlands can come in the Goodyear MT or BFG AT. Thanks
