Status
Not open for further replies.
Kickit
Whelp, I was just up in that area and now I’m wicked mad that I missed seeing them 😫
Advertisement
Lab00Rat
MS
Toyota Tacoma
Those are just "beauty rings" that protects the wheels and can be swapped out. I use to think they were bead locks too.
Source: motor trend interview. Skip to 6:00 min
Yeah, the beadlock-capable rims are an upgrade for the Badlands. Still not known till Build & Pricing if the rims are stand alone option or require Sasquatch to get them.
Yeah, they are not true beadlocks, but skuff guards to keep the mall crawler looking good.
WuNgUn
Ontario Canada
Escape
The beauty rings are there because DOT won't allow bead lockers on the street. They just cover the bolt holes for the lockers. You take the beauty rings off to replace them with beadlockers. Has nothing to do with protecting the rims.
BroncoChicken
Tim
Denver!
‘12 Lexus GX, ‘75 Bronco Sport “Buddy”
You realize that if they took the rear seats out, the cargo area is plenty deep, right? I know the 4-door put the doors in with each one spanning the width of the cargo bay. If these are the doors, they are slid in long ways. I think they might be the doors with the 'hump' in the window line in first, that is why you see that bit peeking up above the body. You guys take everything so literally. Because some Ford marketing douche states that you "can't store the doors in the 2-door", you take that to mean there is no physical way possible to fit them in the vehicle. The Ford guy meant that you can't fit them all in the cargo area and still use the seats. And there won't be any cute little OEM plastic rack thingy to hold them back there. For God's sake, the doors will fit in the back of the thing with the seats folded or removed.
I understand that completely and agree that if you folded seats, you can fit them in the back parallel to the bedsides. But I’ve seen 5 test mules and every one of them have brackets and power inverters mounted in the cargo area. I can promise you the doors are not there.
BroncoChicken
Tim
Denver!
What I was referring to was the 2in lift that is in addition to the squatch package that may or may not be available from Ford. I'm not talking about the suspension on the BL or squatch. I thought the original thread I was referring to was wanting the additional 2in lift on top of the squatch package like the yellow Bronco on 37s.
This: https://www.bronco6g.com/forum/threads/anyone-planning-to-get-a-2”-factory-lift.2611/
Gotcha. I’ve seen people suggesting that the Sasquatch lift is don’t with spacers and that just simply won’t happen. I still think any additional lift from Ford will be done with taller shocks & springs, but who knows what knucklehead dealers will do.
Sub_Sonarman
Paul
San Antonio, Texas
2016 Focus SE, 2018 F-250 Lariat
this stuck out to me as well...its got me a little concerned, coming from a Ram 2500. That looks similar to the seating position in my FJ40...and it’s one of the reasons I can’t do long hours in it.
Supposedly the seats are height adjustable. Looks like the driver is sitting higher than the passenger. Maybe passenger lowered it all the way down just for the picture, so his head wouldn't be cut off by shadow.
Lab00Rat
MS
Toyota Tacoma
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
look at where the guys feet are. he's probably 6ft+. with long legs and his feet all the way back his knees are going to be high. his thighs aren't touching the seat and he's arched forward (shoulders off seat back). this gives it the awkward look. look at the actual seat recline and angle. it's fairly lounged.
if he put his feet forward a bit it'd be much less of an angle.
lrtexasman
Larry
Dallas, Tx
2006 Tundra
Seating position that low is a no go for me. Pre 2020 Tacoma’s have a low position to compensate for the high clearance and low roofline. Don’t want to see that on the Bronco.
Lab00Rat
MS
Toyota Tacoma
More importantly, what kind of apple is that? Looks like a Gala or Fiji.
toymaster
Leonard
Wyoming
2018 F350, 2018 Explorer, 2008 JK
An example of, imitation is the most sincere form of flattery.
Advertisement
Status
Advertisement
