Pretty good fit, cutouts for headrest fold buttons a little crude. Center section doesn't lay flat. Seems like good quality materials and workmanship.
Exactly. Have two dogs and thought the neoprene ones would hold up well and be easy to clean.What do you primarily have this for. Your dog?
I am wondering if this would be the best way to protect the seats from dog nails
That is what we just did on my wife’s sport and I ordered the same for my bronco. It works really well. Plus’s being water proof.What do you primarily have this for. Your dog?
Does the trim ring around the button pop off or did you just tuck it under?I
I used my FordPass points for the same covers. Although they don’t fit as well as the Rough Country neoprene covers I have in my Wrangler I am still pleased with how they fit and function. Notice in the attached pic that I tucked the fabric behind the adjuster trim and it looks much better.
What did the inside surface look like that contacts the factory seating surface? Was it Soft?Pretty good fit, cutouts for headrest fold buttons a little crude. Center section doesn't lay flat. Seems like good quality materials and workmanship.
Not in a Bronco, and not Coverking, but I have had neoprene Wet Okole seat covers in our XTerra for 10 years now, and for most of that time, we have had a 80+ lb dog who rode back there. There has been no damage from the nails, but in my experience, dog hair is pretty hard to remove from the neoprene's knit surface (I think it is nylon?). You will also want to get in under the seats to vacuum with some regularity, we get a chihuahua worth of hair out of there at least once a year. I have heard that squeegee's remove hair easier, but I have not verified that yet.Exactly. Have two dogs and thought the neoprene ones would hold up well and be easy to clean.
I sell dog boots! These are great for protecting from nails: https://www.alldogboots.com/Mesh-Summer-Large-Dog-Booties-Blue-p/ssmblue.htmWhat do you primarily have this for. Your dog?
It just tucked under. The foam(?) underneath has plenty of squish.Does the trim ring around the button pop off or did you just tuck it under?
How can I buy from Ruxer using FP points? I can’t find a way to do so. TIA.These are Ford accessories. Got mine from Ruxer Ford w the B6G discount and used FP points.
