- Jun 21, 2024
- 2
- 32
- 52
- Northern Virginia
- 2024 Everglades
- Everglades
I know for most people this is not worth the effort but I wanted a low risk starter project to get more comfortable with wiring electronics in my Bronco.
Cost: about $50 including purchase of soldering iron and multimeter
Time: about three hours all in, would be much faster for someone with an experience
I successfully wired a garage door opener to my AUX 6 switch using a cheap opener from Amazon and a relay to step down the voltage from 12v to 3v.
First step was cracking open the remote, removing the battery and soldering wires in for power.
Next I connected these wires to a 12v->3v step down relay so the remote doesn’t get fried.
I attempted to find a way to solder the switch under the remotes button to the closed position but ended up having to MacGyver this instead with plastic and tape to hold the button down.
After a bit of trial and error I was able to test this connecting to the AUX wire still in the engine bay and confirm it was working.
Running the wire through to the cabin was easy but my initial plan of hiding the remote under the plastic covering near the drivers windscreen changed because I didn’t want to mess with passing a wire through the A-pillar so close to the airbag. Thankfully I was able to find a secure and more easily accessible location at the base of the A-pillar at dashboard level.
Range seems good after testing and overall this was a really fun way to build my comfort level so I can install lighting on my own.
Plus it’s cool as hell to open the garage door with the switch
