If you read between the lines it says he just doesn't like school bus yellow .I'm confused. Cyber Orange is a great color that shows off the lines and makes the MIC look good. But then it's off your list?
The overland was a stock BL Non-Squatch .Thanks for measuring the tires. Shows why the overland squatch has less fender clearance. Real 35s will be stuffed.
nvm the tire i LOVE that rim!!
@Jman19I'm confused. Cyber Orange is a great color that shows off the lines and makes the MIC look good. But then it's off your list?
what's the offset on these rims?Then I will give you more my brother:
Titan7: Forged, light and super strong. 17x8x5 and weighs about 20.6 pounds. When paired with duratracs, I am about 10.5 pounds lighter per corner.
I am running them on my 2019 Raptor. There will an application for the Bronco and I plan to run Bronze wheels with either CG or Area51:
The Bronco is 5.5 inches wider than an a Rubicon. If I'm on a trail where that 5.5 inches will make a difference then I'm willing to bet I've already said F-it, yolo.Nice pic comparison. The Bronco is a wide arse biotchie.
That is why IMO the Wrangler will fair better on trails and the Bronco will be much more comfortable on road. Select between these two excellent vehicles available for your purpose.
Not sure if you are joking, but a valid question --- looks to be below the top of the rim, which looks like 27", so 24ish? First thing I'm doing is swapping the sliders out for a slider/tube step. Thinking something like this: https://www.rockhard4x4.com/product_p/rh-90104.htmGreat job, can you run back and measure step in height? CG it is for me btw.
