Pinch Weld Cover-Up: Don't Use Adhesive Trim
GrabberBlue
Phoenix, AZ
2010 F-150 Raptor, 2021 Bronco FE
Been looking through old posts about covering up the unsightly pinch weld. It's fully exposed with and without steps and mostly covered up by rock sliders.
I'll make it easy for those thinking of following the advice of others; Do not use adhesive trim strips to cover up your pinch welds. Ford themselves has a kit in the accessories catalog.
Ford Bronco Pinch Weld Cover-Up: Don't Use Adhesive Trim PXL_20210909_192800782
This particular trim curved inward making it difficult to get good adhesion. Additionally it's impossible to get good adhesion over the bolt heads towards the front. This stuff wouldn't last one off-roading trip, a single AZ summer, a winter, or rainstorm.
I will definitely be painting them black when the time comes.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Personally I'd tape it off and shoot some bedliner or rubberized undercoating on it. It'll hide everything and hold up a long time.
jboes13
Joshua
Lexington KY
Line-x does underbody coatings. I'm sure they could do the pinch welds as well. Just an optional alternative to prevent rain/debris buildup that other accessories may cause
Trooper
New York
Ford Escape, Infiniti Q50
Are you referring to the Lund "rocker panels" listed on build and price (see below)?
Did you order them and have a bad experience?
Ford Bronco Pinch Weld Cover-Up: Don't Use Adhesive Trim 1631218425658
  • Like
Reactions: Cat
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
First I've heard of an accessory option for this.
You have a link or photo you can share?
Fly by Nite
Walt
Pa
I wonder if they're designed to leak. Basically let any moisture that gets in there have a way to get out. I'd look into that before applying anything that may seal them.
Rocker panels usually have drains....
The fresh air intake (for interior) at the base of the windshield usually drains down to the rockers. Unsure if the Bronco is also designed this way.
WyoBronc
Kerry
Wyoming
2021 Ranger, 2021 Bronco BB, 2006 Saturn Vue
I installed the Trail Armor rocker panels on my BB yesterday. Looks much better and should provide protection against some of the rock damage we’ve been seeing.
Here’s some before and after photos:
Ford Bronco Pinch Weld Cover-Up: Don't Use Adhesive Trim 14C37927-A019-42BE-B87F-995C5ED1B04C
Ford Bronco Pinch Weld Cover-Up: Don't Use Adhesive Trim 4356258F-9E0B-4C99-B8C5-195A2BFDC5B6
Ford Bronco Pinch Weld Cover-Up: Don't Use Adhesive Trim 24626116-E6BC-4E13-A17F-C977BEB8C160
Ford Bronco Pinch Weld Cover-Up: Don't Use Adhesive Trim 45197C74-D0CD-4872-BA07-0FF4A9C5CE29
West1
DM
Atlanta
Bronco Base with OBX wheels
Ford Bronco Pinch Weld Cover-Up: Don't Use Adhesive Trim BD792D8D-D21B-4FDC-9606-F8951E998041
Looks great. Was it a diy install or did you have the shop install? If it was diy, how hard was it?
Exomodo
Ryan
Marquette, MI
Ranger
Never apply anything that will trap water and debris against the paint and underlying metal. Apply clear paint protection film to flat profiles and bedliner-type material to uneven, low and welded areas like the pinch seams.
My Volvo S60R came from the factory with a polyeurea type undercoating that goes up the lower edge of the car a few inches, basically the entire bottom of the car is sealed, they then painted over that. It has no rust after the first 4 years of its life in Chicago and a few winters in eastern PA. Get to it early and it will keep for a lifetime.
WyoBronc
Kerry
Wyoming
DIY/easy. Just use their clean and prep wipes and attach with affixed 3M tape. You have to remove one screw on each side of the rear wheel well trim and reattach it as it goes over the trail armor. Instructions are provided.
VelocityBronco
E
Looks so much better with the black cover. But living Michigan, I worry about salt and water getting inside and getting trapped.
Does this piece wrap around the pinch weld or just cover the exterior surfaces? Is there a chanel for water to get trapped and sit?
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
Is this piece compatible with the steps?
